Can't install
Posted: Tue Apr 10, 2018 8:05 am
by Tore
I get this when I try to activate Luxcorerender after install. What's going wrong?
Re: Can't install
Posted: Tue Apr 10, 2018 8:20 am
Tore wrote: Tue Apr 10, 2018 8:05 am
Blender 2.79b ?
Did you correctly clean your blender and folder from old Luxblend addon before ?
Re: Can't install
Posted: Tue Apr 10, 2018 9:15 am
by Tore
Blender version (nightly build from april 9th):
blender-2.79.0-git.e0452cc-windows64
I did an uninstall of old version Luxrender in preferences and restarted Blender. What else can I do?
Re: Can't install
Posted: Tue Apr 10, 2018 9:17 am
Custom Blender builds and buildbot builds are not supported.
Source:
https://luxcorerender.org/download/
Re: Can't install
Posted: Tue Apr 10, 2018 9:21 am
Tore wrote: Tue Apr 10, 2018 9:15 am
The path in the screenshot seems to suggest you are using a build from GIT
You have to use the 2.79a/b Blender Foundation official build from blender.org.
Anyway, you can also try to check if there is a pyluxcore.pyd in your "Users/<user name>/AppData/Roaming/Blender Foundation/Blender/2.79/scripts/addons/BlendLuxCore/bin" directory.
Re: Can't install
Posted: Tue Apr 10, 2018 9:33 am
by Tore
Thx for the answer, but unfortunately I can't find the folder you're referring to. I have "C:\Users\Tore" but in here there is no subfolder called Appdata??
Re: Can't install
Posted: Tue Apr 10, 2018 9:34 am
It's hidden by default.
Type %appdata% in your explorer address bar.
Re: Can't install
Posted: Tue Apr 10, 2018 9:45 am
by Tore
Ah, yes of course. Now I found the folder, and it have a file called Pylux.pyd. Tried to delete it, but that didn't go down well, so now it is back. But problem isn't solved, so I guess I'll ave to install another version of Blender then...
Re: Can't install
Posted: Tue Apr 10, 2018 10:05 am
by Tore
Now I have installed Blender 79b and reinstalled LuxCoreRender, and now it works!!! Yaiih! Looking forward to trying it out! Thanks a lot for all the help
Re: Can't install
Posted: Tue Apr 10, 2018 10:25 am
Glad it worked out for you.
