Error when try to render on Linux
Posted: Mon Apr 09, 2018 1:25 pm
Hi when I try to render scene I always see this error message Syntax error in texture name: (numbers)
here error message from terminal
create_session
[SDL][9.908] Camera type: perspective
[SDL][9.908] Camera position: Point[-10.4796, -20.2917, 8.3734]
[SDL][9.908] Camera target: Point[-10.0359, -19.4459, 8.07706]
[SDL][9.908] Camera clipping plane disabled
WARNING: Object "Cube": No material defined
[SDL][9.909] Texture definition: __grid_10cm_1
exporter init
ERROR: Syntax error in texture name: 0.4 0.4 0.4
File "/home/floke/.config/blender/2.79/scripts/addons/BlendLuxCore/engine/viewport.py", line 19, in view_update
engine.session = engine.exporter.create_session(scene, context)
File "/home/floke/.config/blender/2.79/scripts/addons/BlendLuxCore/export/__init__.py", line 105, in create_session
luxcore_scene.Parse(scene_props)
RuntimeError: Syntax error in texture name: 0.4 0.4 0.4
view_update
new session
exporter init
create_session
[SDL][9.919] Camera type: perspective
[SDL][9.919] Camera position: Point[-10.4796, -20.2917, 8.3734]
[SDL][9.919] Camera target: Point[-10.0359, -19.4459, 8.07706]
[SDL][9.919] Camera clipping plane disabled
[SDL][9.920] Texture definition: __grid_10cm_1
exporter init
And if I set material to cube:
LuxCoreRenderEngine del
init
init
view_update
new session
exporter init
create_session
[SDL][157.048] Camera type: perspective
[SDL][157.049] Camera position: Point[-10.4796, -20.2917, 8.3734]
[SDL][157.049] Camera target: Point[-10.0359, -19.4459, 8.07706]
[SDL][157.049] Camera clipping plane disabled
[SDL][157.050] Material definition: 140224315804936
exporter init
ERROR: Syntax error in texture name: 0.69999998807907104 0.69999998807907104 0.69999998807907104
RuntimeError: Syntax error in texture name: 0.69999998807907104 0.69999998807907104 0.69999998807907104
view_update
new session
exporter init
create_session
[SDL][157.062] Camera type: perspective
[SDL][157.063] Camera position: Point[-10.4796, -20.2917, 8.3734]
[SDL][157.063] Camera target: Point[-10.0359, -19.4459, 8.07706]
[SDL][157.063] Camera clipping plane disabled
[SDL][157.064] Material definition: 140224315804936
exporter init
create_session
exporter init
view_update
new session
exporter init
create_session
exporter init
init
init
view_update
new session
exporter init
create_session
exporter init
view_update
new session
exporter init
create_session
exporter init
