Network Rendering Ubuntu 18.04 + Windows 10
Posted: Mon May 25, 2020 11:41 pm
by 3DLV
I'm getting this error with BlendLuxCore-v2.3:
File "/home/leo/.config/blender/2.82/scripts/addons/BlendLuxCore/bin/pyluxcoretools.zip/pyluxcoretools/renderfarm/renderfarmjobsingleimage.py", line 393, in NodeThread
nodeSocket.connect((self.renderFarmNode.address, self.renderFarmNode.port))
I'm very far to be an expert with networking, my setup is very simple
It consists of 2 PCs linked by an ethernet cable setted up with what I think is a static IPs configuration
Remote desktop works fine to control the Windows machine via Remmina with these settings
I'm running the LuxCore NetConsole on the Ubuntu machine
Running up the NetNode on Windows it is added to the NetConsole list
Starting a job I'm getting the above error
Re: Network Rendering Ubuntu 18.04 + Windows 10
Posted: Tue May 26, 2020 12:44 am
You should post the complete error. Do you have some kind of firewall active ?
Posted: Tue May 26, 2020 1:36 pm
by 3DLV
Thank you very much Dade,
I think this was the complete error:
Node thread started
timed out
socket.timeout: timed out
Node thread done
Retrying node: 192.168.1.1:18018
I've checked the Windows 10 firewall and enabled pyluxcoretool.exe to pass through
No firewalls active on the Ubuntu machine as I understand (ufw status: inactive)
Now it is stuck before starting to render
On the NetConsole:
LuxCore 2.3
NetBeaconReceiver thread started.
Discovered new node: 192.168.1.1:18018
Creating single image render farm job: /home/leo/Documents/LuxCore/NetworkCache/LuxCore2.1Benchmark_LuxCore/00001.bcf
New render farm job: /home/leo/Documents/LuxCore/NetworkCache/LuxCore2.1Benchmark_LuxCore/00001.bcf
Job file md5: bcdb427ab152e7a287f02c955c74da1d
Previous scene MD5: bcdb427ab152e7a287f02c955c74da1d
Current scene MD5: bcdb427ab152e7a287f02c955c74da1d
/home/leo/Documents/LuxCore/NetworkCache/LuxCore2.1Benchmark_LuxCore/00001-netrendering exists and is valid. Continue the rendering
Merging all previous films
Job started: /home/leo/Documents/LuxCore/NetworkCache/LuxCore2.1Benchmark_LuxCore/00001.bcf
Node thread started
Film merge thread started
Remote node has the same pyluxcore verison
Sending file: /home/leo/Documents/LuxCore/NetworkCache/LuxCore2.1Benchmark_LuxCore/00001.bcf
Transfered 32.01 Mbytes in 00:00:00 (114.02 Mbytes/sec)
Sending seed: 10
Waiting for node rendering start
And the NetNode:
LuxCore 2.3
Waiting for configuration...
Started
NetBeaconSender thread started.
Waiting for a new connection
Received connection from: ('192.168.1.2', 58718)
Remote pyluxcore version: 2.3
Local pyluxcore version: 2.3
Receiving RenderConfig serialized file: renderfarmnode-aba59288-869e-4edb-88cb-babeea898720.bcf
Receiving file: renderfarmnode-aba59288-869e-4edb-88cb-babeea898720.bcf
Transfered 32.01 Mbytes in 00:00:00 (104.92 Mbytes/sec)
Receiving RenderConfig serialized MD5: bcdb427ab152e7a287f02c955c74da1d
Received seed: 10
Reading RenderConfig serialized file: renderfarmnode-aba59288-869e-4edb-88cb-babeea898720.bcf
[SDL][14.438] Loading serialized mesh: Mesh_Plane__013140281056706568000
[SDL][14.453] Loading serialized mesh: Mesh_Box057140281056268808000
[SDL][14.453] Loading serialized mesh: Mesh_Box057140281056268808001
[SDL][15.235] Loading serialized mesh: Curve_Plane__021140281056717320000
It's also showing a -Waiting for a new connection- message on the NetNode window frame
Posted: Wed May 27, 2020 1:53 pm
Ok, so you don't get the error anymore
There has been some report of freezes when lunching network rendering from Blender while it works fine as stand alone:
viewtopic.php?f=4&t=2037#p21966
Are you lunching the rendering from Blender or from command line ?
Posted: Wed May 27, 2020 5:56 pm
by 3DLV
So, the first error is not happening anymore since I've allowed pyluxcoretool.exe to pass through the firewall on Windows 10
Running the console on Windows seems to work fine if the Ubuntu node is set up with the right host and broadcast IPs
I've just thrown half a render on cpu (no openCL) without splitting workloads and it was going ok
The opposite way, running the console on Ubuntu, the Windows node keeps getting stuck
I'm running all of this from GUIs
Posted: Wed May 27, 2020 6:34 pm
by 3DLV
Ok, I think I get it now
The issue happens when the LuxCore NetNode is loaded up from Blender's GUI on Windows
It all seems to work fine if the Windows node is being run instead by using the pyluxcoretools executable from the Blender addons folder
Posted: Wed May 27, 2020 6:39 pm
3DLV wrote: Wed May 27, 2020 6:34 pm
Have you installed Blender with admin rights so it (and pyluxcoretools) can not write in its directory ? It may explain the problem (network rendering requires to create several temporary files).
Posted: Wed May 27, 2020 6:45 pm
by 3DLV
Sorry, I´m not sure, I think it is
I'm just unzipping Blender, moving it to my Program Files folder and launching it from a shortcut
