Help to get Network Render working with Unbuntu 18.04
Posted: Mon May 25, 2020 4:04 pm
by 3DLV
Help,
I'm trying to get Network Render working on Ubuntu 18.04
I've tried the GUI LuxCore Network Render button and a -sudo pip3 install PySide- on terminal
It seems that Python-3.6 pip3 (which is what I get using -apt install python3-pip-) is not supported to install PySide
I can't figure out a way to install a supported version like Python-3.4 pip3, if it makes any sense
Any help, would be greatly appreciated
Leo
Edit: I'm using BlendLuxCore 2.3 w/OpenCL support
Re: Help to get Network Render working with Unbuntu 18.04
Posted: Mon May 25, 2020 4:08 pm
Have you tried with PySide2 ? What LuxCore version are you using ? We droped PySide1 at one point :?:
Posted: Mon May 25, 2020 5:37 pm
by 3DLV
Sorry, I forgot to mention, I'm using BlendLuxCore-v2.3-linux64-opencl, thanks a lot Dade
I've installed Python-Minimal (2.7.17), pip and managed to get PySide2 installed
After trying again the GUI LuxCore Network render button I had some errors so I've installed pip3
Trying again now it's popping up -You need PySide. Install it now?-
Posted: Mon May 25, 2020 5:47 pm
by Fox
Pyenv tutorial https://www.youtube.com/watch?v=fv8YxO3AJqg
Install python
python3 -m pip install virtualenv numpy
pip install --upgrade virtualenv pip
python3 -m pip install virtualenv pyinstaller
python3 -m pip install virtualenv PySide2
Posted: Mon May 25, 2020 6:23 pm
3DLV wrote: Mon May 25, 2020 5:37 pm Sorry, I forgot to mention, I'm using BlendLuxCore-v2.3-linux64-opencl, thanks a lot Dade
Ubuntu has 2 version of Python, v2.7 and v3.x. They are not compatible so you must be careful on what you use (python or python3) and what you install (for python or python3). It is quite confusing. LuxCore needs Python v3.x stuff.
Fox's suggestion to use virtual env. is a quite good hint.
Posted: Mon May 25, 2020 8:22 pm
by 3DLV
Dade, Fox, thanks a lot,
Following this helped to run the PyLuxCore Tools from Blender (2.82a)
sudo apt install python3
sudo apt install python3-pip
Fox wrote: Mon May 25, 2020 5:47 pm python3 -m pip install virtualenv numpy
