LightTracing BlendLuxCore 2.3 vs. BlendLuxCore 2.4 ?
Posted: Mon May 18, 2020 1:24 pm
by denon100
is this behavior normal in BlendLuxCore 2.4 with LightTracing?
If the LightTracing is on or off, the material colors change.
Have otherwise made no changes.
This does not happen with BlendLuxCore 2.3.
thank you
Blender 2.8
Windos 10 Pro version 1909
Ryzen 9 3900x
RTX 2070 Super
Re: LightTracing BlendLuxCore 2.3 vs. BlendLuxCore 2.4 ?
Posted: Mon May 18, 2020 1:44 pm
Are you using automatic tonemapping?
Can you upload the scene?
Posted: Mon May 18, 2020 1:56 pm
by denon100
No matter whether tonemapping is on or off.
thank you
Lighttracing.blend
(751.26 KiB) Downloaded 456 times
Posted: Mon May 18, 2020 3:58 pm
It is a view port rendering with and without light tracing (PATHCPU Vs RTPATHCPU) :?: Do you get the same results in final rendering (i.e. PATHCPU Vs. PATHCPU) ?
Posted: Mon May 18, 2020 4:29 pm
by denon100
final rendering identical to viewport rendering :!:
by the way, everything works with the Disney material :?
as in BlendLuxCore 2.3
Posted: Wed May 20, 2020 12:12 pm
by denon100
am I the only one with this problem ?
Posted: Fri May 22, 2020 10:18 am
by Luximage
I have the same problem with you denon100.If i change the plane material to disney or glossy or metal with roughness included to Light tracing glossiness threshold it works ok.
win 10, xeon e5620, gtx 1050 ti
blender 2.82, latest daily blendluxcore 2.4 cuda
Posted: Fri May 22, 2020 1:00 pm
It was a bug in MIS code when rendering env. light sources with light tracing. I should have fixed the problem.
Posted: Fri May 22, 2020 3:06 pm
by denon100
Hello,
and thank you very much for your endless efforts.
Thank you :P
