What is differance?
Posted: Sat May 16, 2020 7:57 am
What is differance from this two Windows64 builds?
Win64-cuda vs Latest-win64? On speed or what else?
3rd build: is it supported SEE3.X for OIDN or is it need at least SEE4.1?acasta69 wrote: Sat May 16, 2020 9:02 am The difference is that with the first two builds you can choose GPU-based render engines (e.g. PathOCL), having much better performance in many cases.
The first build has Cuda enabled: you can use it if you have a suitable Nvidia GPU. Many users reported better performance using the Cuda build with Nvidia GPUs instead of the more generic OpenCL build.
The second build has OpenCL enabled, but not Cuda: you can use it with any GPU, either Nvidia or AMD.
The third build does not have any GPU acceleration enabled: you can only choose CPU-based render engines (Bidir, PathCPU), but it will run basically on any PC, even a laptop with very low-end graphics card, where probably no GPU acceleration support is available.
SEE4.1 is a ODIN library requirement (not a LuxCore one) so it is needed by all versions.Odilkhan Yakubov wrote: Sat May 16, 2020 9:36 am 3rd build: is it supported SEE3.X for OIDN or is it need at least SEE4.1?
Ok. I understand nowDade wrote: Sat May 16, 2020 10:00 amSEE4.1 is a ODIN library requirement (not a LuxCore one) so it is needed by all versions.Odilkhan Yakubov wrote: Sat May 16, 2020 9:36 am 3rd build: is it supported SEE3.X for OIDN or is it need at least SEE4.1?
