Luxcore 2.4 CUDA not working
Posted: Tue May 05, 2020 7:17 pm
by phoenixart
I'm trying Luxcore 2.4 CUDA and I'm having a couple of issues.
First thing I noticed after the installation is that I get a warning about the AI_denoise_addon missing.
Then, when I switch to Luxcore I only see two options: CPU and OpenCL.
Am I missing something?
I got the latest build from here:
https://github.com/LuxCoreRender/BlendLuxCore/releases
Thanks for any help.
Re: Luxcore 2.4 CUDA not working
Posted: Tue May 05, 2020 7:47 pm
phoenixart wrote: Tue May 05, 2020 7:17 pm Then, when I switch to Luxcore I only see two options: CPU and OpenCL.
Select OpenCL and than go in the device list and you will see your GPU is listed 2 times: one as OpenCL device and one as CUDA device, just select only the CUDA device.
BlendLuxCore has not yet been updated.
Posted: Tue May 05, 2020 7:57 pm
by phoenixart
Thank you, Dade
Of course, I realized that right after I posted :)
This is how the device list looks on my end
which I thought it was a little confusing as it shows 4 devices for the OpenCL and two for the CUDA (I have two 1080ti)
Anyway, after I start a viewport shading this is what happens
and basically nothing happens even if I wait for a few minutes.
The only thing I can do at this point is to end the Blender from the task manager.
Posted: Tue May 05, 2020 8:01 pm
by phoenixart
Never mind, it seems now it's working although the viewport is quite unresponsive (I only have the default cube in the scene)
Posted: Tue May 05, 2020 11:01 pm
phoenixart wrote: Tue May 05, 2020 7:57 pm which I thought it was a little confusing as it shows 4 devices for the OpenCL and two for the CUDA (I have two 1080ti)
This is a bit strange, you should try LuxMark and check how many devices it lists. You should see only 2 OpenCL devices.
P.S. the first (and only) time you run a render engine on a device, LuxCore has to compile the GPU kernels and it takes quite some time (about 2 mins on a AMD 3900X).
Posted: Wed May 06, 2020 6:37 am
by phoenixart
Strange indeed, LuxMark lists 4 GPUs:
Posted: Wed May 06, 2020 9:13 am
phoenixart wrote: Wed May 06, 2020 6:37 am Strange indeed, LuxMark lists 4 GPUs:
It is very strange and if it happens with LuxMark it is likely to be a bug in some NVIDIA driver release. LuxMark has not been touched and has worked for years.
