Problem Installing on OSX
Posted: Fri Apr 17, 2020 7:12 pm
by dcamino
Hi, I am trying to install Luxcore on my computer and every time I try to activate the addon, Blender crashes.
It only gives me Bus error: 10.
This my system info:
Model: MacPro5,1, 12 processors, 6-Core Intel Xeon, 2,8 GHz, 64 GB, SMC 1.39f11
Graphics: NVIDIA GeForce GTX TITAN X, NVIDIA GeForce GTX TITAN X, PCIe
Thanks in advance and regards.
Re: Problem Installing on OSX
Posted: Fri Apr 17, 2020 8:01 pm
Posted: Fri Apr 17, 2020 10:27 pm
by dcamino
Hi, thanks. But they are saying there that it is already solved and it is not true. I have the latest version of Blender installed and it gives me an error.
Any idea?
Thx & regards.
Posted: Mon Apr 27, 2020 8:31 pm
by dedwarmo
I'm having the same problem trying to enable BlendLuxCore-v2.3-mac64.
I'm running Blender 2.82a on macOS 10.15.2.
Posted: Tue Apr 28, 2020 8:03 am
by epilectrolytics
dedwarmo wrote: Mon Apr 27, 2020 8:31 pm I'm having the same problem trying to enable BlendLuxCore-v2.3-mac64.
From what I remember (currently messing with the new Cuda versions on my PC) about BlendLuxCore 2.3 on OSX it will only run on High Sierra and probably only with Blender 2.81.
Certain Fixes and notarization for OSX 10.14 and higher are only available in the daily builds of LuxCore 2.4 alpha.
(Which ATM has OpenCL broken.)
Posted: Tue Apr 28, 2020 3:25 pm
by u3dreal
Hello all,
2.3 release only works with Blender 2.81a and down.
Signing was added to the release download so it should work on High Sierra and up and was confirmed by users.
2.4alpha will only work with Blender 2.82a and up. It should work on High Sierra and up.
BYOB also added a version check for 2.4alpha but it has not been added to 2.3 release.
Maybe i should do that so the issue is self explanatory.
Posted: Tue Apr 28, 2020 3:30 pm
u3dreal wrote: Tue Apr 28, 2020 3:25 pm BYOB also added a version check for 2.4alpha but it has not been added to 2.3 release.
If you could do that, it would be great :)
Posted: Tue Apr 28, 2020 4:14 pm
by u3dreal
Done .. uploading. If someone could test would make me happy.
@B.Y.O.B
i added the following
import bpy
import platform
if platform.system() == "Darwin":
    if bpy.app.version > (2, 81, 16):
        raise Exception("\n\nUnsupported Blender version. 2.81a or lower is required.")
    mac_version = tuple(map(int, platform.mac_ver()[0].split(".")))
    if mac_version < (10, 13, 0):
        raise Exception("\n\nUnsupported Mac OS version. 10.13 or higher is required.")
