Add support for Blender 2.83 Volume Object
Posted: Mon Apr 06, 2020 7:58 am
by melMass
Hi All,
I'm a pretty new user of LuxCore, and I love it a lot.
I was wondering if there is a plan to support Blender's new volume object in LuxCore?
This is there new builtin way to import VDB
Thanks
Re: Add support for Blender 2.83 Volume Object
Posted: Mon Apr 06, 2020 9:06 am
It will be supported eventually, but probably not before the first stable version of Blender with this new feature is out.
Posted: Mon Apr 06, 2020 10:21 am
by melMass
Of course, it makes sense!
I might give it a go myself then
I have yet to discover BlendLux sources but I'm getting familiar with LuxCore sources right now by adding textures!
Posted: Wed Apr 08, 2020 8:58 am
by juangea
The volume object does not even support mantaflow yet
mantaflow support is more important right now I think
Posted: Sat Apr 18, 2020 12:16 am
by melMass
There is no way to import VDB from Houdini right?
It's only available in standalone? I can't find a doc on the VDB node and from the forum, I'm not sure if it's already integrated
Posted: Sat Apr 18, 2020 7:17 am
by neo2068
It is supported. You can select the vdb file exported from houdini in the openvdb node. In animations there still is some jittering because the adaptive domain transformation isn't correct. I have a fix for that but it is not available in the daily builds. I will try to push it in the next days.
