Page 2 of 4
Re: b2przemo renders
Posted: Fri Oct 02, 2020 11:03 am
by Dez!
Yes, you can't take your eyes off the metal in Luxcore, it's beautiful!
Posted: Sat Oct 03, 2020 8:57 pm
by b2przemo
Dez! wrote: ↑Fri Oct 02, 2020 11:03 am
I've tried to use Supra files which works nicely, but finally when it comes to tweaking shader IMO is better to do it in an Artistic way - judging by the preferred appearance. You got some nice metals in Your renders, I like the hyperrealistic look when everything is perfect.
Another small idea of the office. Post in DarkTable. About 1000spp without denoising.
Lollipop Lady
Posted: Sat Oct 10, 2020 7:57 pm
by b2przemo
An old personal project of roller girl. Finished after a very long time. I almost forgot about her
Black Whiskey
Posted: Tue Oct 20, 2020 9:22 pm
by b2przemo
Black whiskey on the black background. It's not so obvious in the rendered image but glass has some rough dirt on it (fingerprints) and probably caustics should be stronger to lit the background a bit. No denoise, 1024 spp. Very subtle postproduction in the Darktable (lowering saturation, add brightness).
some attempts
Posted: Wed Oct 28, 2020 3:47 pm
by b2przemo
I did it mostly for practicing procedural texturing and lighting in Lux. Greenery was done with instanced geometries over scattered hair systems that's why it has overlapping geometries.
Posted: Wed Oct 28, 2020 4:12 pm
I'm definitely a fan of your interior renders. The second pic is so well done , great mood
Posted: Thu Oct 29, 2020 2:08 am
by Dez!
beauty!
woooooow
white kitchen 1
Posted: Sat Oct 31, 2020 7:50 pm
by b2przemo
Thanks, guys
Below, a white kitchen project - practicing high-key lighting in Lux Core. I'm not so sure about white balance
I don't have any proper calibration tool and each machine display different white values - one is cold and the other display as more contrasted warmer image... so I'm not sure how it will look like on your screen but I aimed for 5800K
Evo chairs from Paged furniture company and Tamazo table designed by Swallows Tails.
Posted: Sat Oct 31, 2020 11:30 pm
The design and shading look great.
Only the lighting is down from my POV.
Look like unrealistic lamp light and shadow.
To sharp to flat no variation.
A good hdri from hdri haven could give this scene the deserved lighting.
Posted: Sun Nov 01, 2020 2:46 pm
by b2przemo
Sharlybg wrote: ↑Sat Oct 31, 2020 11:30 pm
Thank You for feedback.
I've used hdri texture together with 4 lamps but the final outcome still was very noisy and I wasn't able to find what was caused the performance issue. In opposite to previous renders, the geometry for the building was closed this time, the glass window was made from arch glass shader. I tried to achieve something like very bright overcast from window but still preserve some details in white wood (bump, spect etc). The problem is that when it comes to the scenario where filmic false colors show dark blues and reds the rendering becomes far more difficult and slower to remove the noise. Normally with values like grey/green, the noise disappears about 100-200 samples... in this particular scenario, I wasn't able to get rid of it in 2000spp. I probably do some errors with light values, I used lumens and don't change any special settings in lux itself (standard cache setup nothing fancy, log power for lights). I tried to balance shaders values (it make a quite big performance difference if there is a too big contrast between blacks and whites materials) and check how light paths values can lit the darken spots more - that's why there are these additional lights that incorporate some lighting, without them the concrete over the window was very noisy.
