RT Mod
Posted: Mon Apr 02, 2018 10:34 am
Just wonder :
___ Why Material preview always show rough glass totally Dark
___ If RT will support GPU acceleration
Re: RT Mod
Posted: Mon Apr 02, 2018 11:14 am
Sharlybg wrote: Mon Apr 02, 2018 10:34 am
Just wonder :
The default specular max. path depth ("path.pathdepth.specular") is set to 3 and it is not enough to render 2 overlapped glass surfaces (i.e. 4 bounces). Yes, it may be better to raise the default limit to 5.
It is already available (and I think it is also supported by BlendLuxCore). However you are going to hit a lot of kernel compilations when you edit materials, textures, etc. It is the reason why the CPU version is better.
Re: RT Mod
Posted: Mon Apr 02, 2018 11:50 am
Rough glass is a glossy material. Glossy depth was set to 2.
I raised it to three and now rough glass works as expected.
Dade wrote: Mon Apr 02, 2018 11:14 am
In BlendLuxCore it is currently not possible to use RT OpenCL.
It would be easy to expose, but as you said, it is usually not worth the trouble to use it because of the many recompilations.
Eventually I will expose this setting, it is just one of the things where the time/gain ratio was bad
Re: RT Mod
Posted: Wed Apr 04, 2018 10:40 am
This is directly from "Bring Arnold to GPU" presentation at last GTC (
http://on-demand.gputechconf.com/gtc/2018/video/S8841/):
It shows how CPUs generate the first samples faster than GPUs while the GPUs win on the long run. Exactly why we use RTPATHCPU over RTPATHOCL.
The Redshift presentation is quite interesting too:
http://on-demand.gputechconf.com/gtc/2018/video/S8404/
Big new features:
- light groups AOV ... check, done many years ago
- Ray traced SSS ... check, done many years ago
Ahhh, we may have done a lot of wrong things in 10 years of LuxRender but we have also seen a lot of stuff coming many years before some of the major player in this field
Re: RT Mod
Posted: Wed Apr 04, 2018 1:10 pm
by kintuX
Yes, Lux is an amazing engine and you're practically all real geniuses - great minds with big hearts
Simply can't express how grateful i am... so hopefully i'll show it
