Luxcore Shader for noobs 2
Posted: Fri Mar 27, 2020 10:45 pm
Second part of the Blender 2.8 Luxcore Shader tutorial cover translucent material and its application :
__Skin
__ Cloth
__ Curtain
__ Paper
__ Plastic
__ Candle
__ Marbles
Youtube Link
https://youtu.be/79V_ySn5ZoY
Blenderartists Link
https://blenderartists.org/t/luxcore-sh ... -2/1215978
Re: Luxcore Shader for noobs 2
Posted: Fri Mar 27, 2020 11:01 pm
by wasd
Please, do something with sound. I can barely hear your voice. Can you move computer farther from microphone? There's too much fan noise.
Posted: Sat Mar 28, 2020 1:44 am
by wasd
Posted: Sat Mar 28, 2020 2:38 am
by PDRA
Very nice tutorial!
Only one suggestion. I've noticed that it takes a bit too much time to load the video. Maybe it is due to its size.
I recommend you this tool:
http://www.h264encoder.com/
After recording and editing, render again the video with the "high quality" option.
It helps to reduce a lot the size. For instance, one video I had of 2gb video was reduced to only 300 mb.
Hope it helps you!
Regards, saludos
Pablo
Posted: Sat Mar 28, 2020 7:36 am
PDRA wrote: Sat Mar 28, 2020 2:38 am
Very nice tutorial!
Hope it helps you!
Regards, saludos
Pablo
Finally an angel come with a solution for this big issue. Thanks a lot.
Posted: Sat Mar 28, 2020 5:23 pm
by PDRA
Sharlybg wrote: Sat Mar 28, 2020 7:36 am
I'm glad I helped you!
Posted: Sat Mar 28, 2020 5:28 pm
by PDRA
One more tip that could help. You can use the "Screencast keys" addon to show the shortcuts you use.
Even though your tutorials are oriented to rendering, sometimes for those who are learning is a very good addition to know which keys you are using.
An alternative to it is a program called "Carnac".
Posted: Thu Apr 02, 2020 8:03 pm
by wasd
"skin" with camera volume enabled:
and disabled:
