Meshlight intensity problem
Posted: Wed Mar 28, 2018 1:22 pm
by Odilkhan Yakubov
I used one mesh for emitter, but when i change every settings in Emitter node nothing changed on mesh intensity. What is my mistake?
Re: Meshlight intensity problem
Posted: Wed Mar 28, 2018 1:52 pm
Odilkhan Yakubov wrote: Wed Mar 28, 2018 1:22 pm I used one mesh for emitter, but when i change every settings in Emitter node nothing changed on mesh intensity. What is my mistake?
Are you using tone mapping auto-linear or something similar ? You need to use a linear tone mapper or the auto-linear tone mapper will scale down the general image light intensity every time you scale up the light intensity.
Posted: Wed Mar 28, 2018 1:53 pm
Maybe you are using an automatic tonemapper?
See "when I change the brightness of my lamp, nothing happens"
The tonemapper settings are in the camera tab, imagepipeline panel.
Posted: Wed Mar 28, 2018 1:55 pm
by Odilkhan Yakubov
I used always Filmic LUT and Base contrast on the preset.
Posted: Wed Mar 28, 2018 2:11 pm
That has nothing to do with your problem.
Look into the camera settings, disable the automatic tonemapping.
If you need it I can post a screenshot.
The wiki section on this topic is not yet written unfortunately.
Posted: Wed Mar 28, 2018 2:52 pm
by Odilkhan Yakubov
B.Y.O.B. wrote: Wed Mar 28, 2018 2:11 pm That has nothing to do with your problem.
Ok, ill check
Posted: Wed Mar 28, 2018 7:46 pm
stay well ;)
Posted: Thu Mar 29, 2018 1:23 am
by Odilkhan Yakubov
Thank you guys. Solved! ;)
