Page 1 of 2
Colorspace and primaries
Posted: Sat Feb 22, 2020 12:47 pm
by Egert_Kanep
Is luxcore using rec709 colorspace, would it be possible to add ocio support to luxcore?
Re: Colorspace and primaries
Posted: Sat Feb 22, 2020 1:24 pm
Egert_Kanep wrote: Sat Feb 22, 2020 12:47 pm Is luxcore using rec709 colorspace
The answer should be yes because it uses sRGB space that is part of 709.
Egert_Kanep wrote: Sat Feb 22, 2020 12:47 pm would it be possible to add ocio support to luxcore?
It is possible but I think the raw LuxCore outputs is the input of Blender image pipeline so if you have OCIO in Blender it should be applicable to BlendLuxCore too.
Posted: Sat Feb 22, 2020 2:29 pm
by Egert_Kanep
When we do colorconversion after rendering we are stuck with small srgb gamut then. But would it be possible to have already aces gamut inside luxcore?
Posted: Sat Feb 22, 2020 3:22 pm
Egert_Kanep wrote: Sat Feb 22, 2020 2:29 pm When we do colorconversion after rendering we are stuck with small srgb gamut then. But would it be possible to have already aces gamut inside luxcore?
You get out what you throw in: I mean that LuxCore just transports values and uses 32bit floating point resolution for each component so it is more up to Blender/BlendLuxCore as far as I know.
Posted: Sat Feb 22, 2020 4:55 pm
by Fox
What about filmic tonemapping in LuxCoreUi :?:
Posted: Sat Feb 22, 2020 8:52 pm
by chafouin
You can use the filmic tonemapping from Blender as well. Color management in Blender works the same way as with Cycles.
But maybe you use LuxCore outside of Blender?
Posted: Sat Feb 22, 2020 9:18 pm
by Fox
chafouin wrote: Sat Feb 22, 2020 8:52 pm You can use the filmic tonemapping from Blender as well. Color management in Blender works the same way as with Cycles.
Yes. but, is there way to load the outside exr file to Blender and apply filmic?
Posted: Sat Feb 22, 2020 9:53 pm
by chafouin
You can probably use the filmic ocio config in your compositing software.
https://www.maximeroz.com/filmic-nuke
I haven't tried it personally though.
Posted: Wed Feb 26, 2020 6:25 pm
by Egert_Kanep
@dade
I'd still like to bother you a bit with this colorspace thing. I'm not sure how much work this would be, but maybe at least to consider doing it at some point.
Here is an article about the aces and hkw rec2020 would be better option for rendering colorspace. I do not totally yet understad this particular topic myself, but it seems like using wider gamut is unavoidable if LuxCore would be to keep up with the standards.
Or maybe to start rendering in aces rather than even in rec2020
https://chrisbrejon.com/cg-cinematograp ... comparison
Posted: Wed Feb 26, 2020 8:20 pm
by Egert_Kanep
Better yet to have full support for ocio colormanagment.
