Materials
Posted: Sun Mar 11, 2018 6:47 pm
by 400ml
I noticed when using the bump node that you are allowed to put in a number string that is not shown in the view port. For example I have .003 entered and results shown is 0.00
Which is reflected on material results as well.
Re: Materials
Posted: Sun Mar 11, 2018 7:05 pm
by Asticles
Also happens with camera linear exposure.
Re: Materials
Posted: Sun Mar 11, 2018 8:28 pm
by jensverwiebe
400ml wrote: Sun Mar 11, 2018 6:47 pm I noticed when using the bump node that you are allowed to put in a number string that is not shown in the view port. For example I have .003 entered and results shown is 0.00
Add more precision in the property. Its easy to find.
Re: Materials
Posted: Mon Mar 12, 2018 6:37 pm
I think this is a Blender limitation (it does not automatically add more digits after the decimal point).
I can raise the amount of digits after the decimal point, but it is fixed.
It's annoying to have 2.00000000 everywhere, too, so we have to find a balance.
jensverwiebe wrote: Sun Mar 11, 2018 8:28 pm Add more precision in the property. Its easy to find.
As far as I know this can only be done in the Python code of the addon, or is there a way for a user to change the precision?
edit: by the way, 400ml, you are supposed to plug the texture into the upper slot.
The lower slot that is currently obscured in your setup is set to the "Distance" type which handles this case a bit better.
Re: Materials
Posted: Tue Mar 13, 2018 6:21 pm
by jensverwiebe
B.Y.O.B. wrote: Mon Mar 12, 2018 6:37 pm
Not quite, but i thought i am in the developer forum here ? :lol:
Meant more right-click -> edit source ;)
Re: Materials
Posted: Sat Mar 17, 2018 4:35 am
by 400ml
B.Y.O.B. wrote: Mon Mar 12, 2018 6:37 pm I think this is a Blender limitation (it does not automatically add more digits after the decimal point).
Thanks, I agree with all the zeros being somewhat annoying.
