Page 3 of 6
Re: What is new in LuxCore API v2.0?
Posted: Sun Mar 25, 2018 8:39 pm
Dade wrote: ↑Sun Mar 25, 2018 8:22 pm
I'm working on the new volume rendering code. this is a cube with a volume defined by an FBM procedural texture:
BTW, what is exactly the status of Blender support for OpenVDB file format ?
I could very easily add the support for .vdb format but it is going to be a bit useless if Blender can not save the volume data in that format.
Posted: Sun Mar 25, 2018 8:49 pm
Seems like it is supported since 2.77:
https://wiki.blender.org/index.php/Dev: ... e_Features
(Scroll to "OpenVDB caching", there is also a commit linked, maybe with technical information).
OpenVDB version in Blender seems to be 3.2.0:
https://docs.blender.org/api/2.79/bpy.a ... pp.openvdb
See also
https://wiki.blender.org/index.php/User ... mokeExport
Posted: Sun Mar 25, 2018 10:24 pm
Simon, so you can pass me a .vdb filename in a new ".file" property instead of the ".data" property in density grid texture, right ?
Can you post a test .vdb exported by Blender for testing ?
I think we can release beta1 with the new volume rendering code and beta2 with .vdb support (the only time consuming part of adding OpenVDB support is adding OpenVDB library to Linux and Windows binary dependency repositories).
Posted: Sun Mar 25, 2018 10:44 pm
by kintuX
oh, this is so good... was only silently hoping, but what a great day has turned out to be... good times come
ie.
Houdini VDB in Blender aLa deLux
Posted: Mon Mar 26, 2018 6:47 am
Dade wrote: ↑Sun Mar 25, 2018 10:24 pm
Yes.
I'll prepare a few variations in the evening.
Ok.
Posted: Mon Mar 26, 2018 9:12 am
by jensverwiebe
On linux and osx you do not even need the libs explicite, only headers for compiling.
The module pulls its symbols from the host app just like it does with python.
Avoid this lib delivery overkill.
Posted: Mon Mar 26, 2018 6:50 pm
Here is the same simulation baked with 3 different compression methods.
I also added one version with half float format (blosc compression) - the others support this, too.
Download button in the upper right corner.
https://drive.google.com/open?id=1eWqt7 ... RKKgkTNjcJ
Posted: Mon Mar 26, 2018 9:45 pm
by neo2068
That‘s great news. What are the improvements compared to the old code?
Posted: Mon Mar 26, 2018 10:04 pm
neo2068 wrote: ↑Mon Mar 26, 2018 9:45 pm
It is a lot faster and it works
I must admit I have still aliasing problem with sharp edges but there aren't usually a lot of sharp edges in most common heterogeneous volumes (i.e. smoke, etc.).
Just compile the latest sources and try to use an heterogeneous volume with density grid (btw, I added the OpenCL support for density grid texture too).
Posted: Tue Mar 27, 2018 7:16 am
by neo2068
Dade wrote: ↑Mon Mar 26, 2018 10:04 pm
OpenCL support is really great. Thanks for that. I tried to implement that some time ago but only got frustrated as debugging the code was a nightmare. Is there an automatic step size estimation for heterogeneous volumes? Aliasing was bad with the old code, too, and multiple scattering volumes wasn't as bright as rendered with other renderers. I have to try it.
