LuxCoreRender v2.0alpha6 released
Posted: Tue Mar 06, 2018 5:58 pm
New LuxCoreRender v2.0alpha6 release is available at:
https://luxcorerender.org/download
v2.0 release notes are available here:
https://wiki.luxcorerender.org/LuxCoreR ... Notes_v2.0
The complete list of changes between alpha5 and alpha6 in Luxcore API is available here:
https://github.com/LuxCoreRender/LuxCor ... v2.0alpha6
The complete list of changes between alpha5 and alpha6 in BlendLuxCore is available here:
https://github.com/LuxCoreRender/BlendL ... v2.0alpha6
This version includes the fix of some crashes, sphere light source, Blender render layer support and material preview (I think, B.Y.O.B.
Re: LuxCoreRender v2.0alpha6 released
Posted: Tue Mar 06, 2018 6:09 pm
Dade wrote: Tue Mar 06, 2018 5:58 pm
This version include the fix of some crashes, sphere light source, Blender render layer support and material preview
Yes. Also:
- Added a bunch of imagepipeline plugins (vignetting, mist, color aberration, irradiance/contours etc.)
- Fixed some rare issues with border rendering
- Added UV mapping rotation
- Much faster final render updates (film refreshes)
- IOR support for glossy2 (people will celebrate I guess)
- Fixed an age-old bug in camera DoF object handling, leading to issues if e.g. the camera was parented to some object
- Added support for material ID
- Added drawing handler that shows the point light sphere radius in the 3D view (OpenGL)
- Fixed this bug:
https://github.com/LuxCoreRender/BlendLuxCore/issues/69
And a lot of smaller stuff that's not really worth mentioning, you can read the commit messages linked above if you want to know it all
Posted: Tue Mar 06, 2018 6:43 pm
Thanks for the hard work great job !
Posted: Tue Mar 06, 2018 7:09 pm
by david57
Thank you...
Posted: Tue Mar 06, 2018 8:12 pm
Note that even if the download comment say alpha 5 you can still download it as the link refer to alpha 06.
Posted: Tue Mar 06, 2018 9:07 pm
I updated the titles.
Posted: Tue Mar 06, 2018 11:34 pm
Thank you.
Win7, b2.79a, LC2a6
First couple of mishaps or bugs (New scene, Cube+Sun+Sky+Camera):
1. Update OpenCL device list doesn't work (no action performed, empty console).
/ f12
Unknown render engine type in RenderEngine::FromProperties(): PATHOCL
2. Halt Conditions duplicated? (1. in Render, 2. in Render Layers)
3. Mist causing jagged edges with 'Exclude Background' is that ok?
4. Clamp Output causes horizontal lines in Display & some kind of dotted artifacts. Which keep appearing after clamp is disabled.
No OCL render means i couldn't test if 'Build Visibility Map' is fine now.
Late now... will continue tomorrow.
Otherwise, feels much better, great response time. Smooth. Thanks again...
Posted: Wed Mar 07, 2018 7:12 am
kintuX wrote: Tue Mar 06, 2018 11:34 pm
Make sure you have an OpenCL build.
Maybe you should open an issue/thread for this so we can investigate further.
The halt conditions of a render layer override the global halt conditions.
This is a limitation of the Depth-AOV (it is not anti-aliased).
I recommend not to use such a strong mist that it becomes obvious, only use it for light aerial perspective in the distance (1-2km) in open scenes.
I think we could add an extra "Mist" AOV with AA but that seems like overkill for a fake-plugin that will be rarely used anyway (at least I think that).
Please upload a test scene and open an issue/thread.
I don't think the visibility map needs OpenCL.
Thanks for your feedback
Posted: Wed Mar 07, 2018 7:38 am
by Stem
Have downloaded and tried both windows builds (just in case naming of builds was incorrect), nither will update/show devices, so cannot render with openCL. (alpha5 was OK)
Posted: Wed Mar 07, 2018 8:10 am
by marcatore
the same here.
The openCl doesn't recognize any devices.
Alpha5 was OK
