world in material id color
Posted: Wed Oct 23, 2019 11:02 am
by Egert_Kanep
Is it possible to exclude world from material id color aov? I cannot use alpha to cut it out because this is antialiased and white world color bleeds into other id's
Re: world in material id color
Posted: Wed Oct 23, 2019 2:03 pm
Are you looking of an object mask for composing ? You should use OBJECT_ID_MASK AOV
Posted: Wed Oct 23, 2019 2:05 pm
by Egert_Kanep
Not object mask. I'm strictly using only material color id masks, because I can use this to create perfect rgb masks. Other ID masks use some weird hacks in Blender to create anti aliasing and what else.
Altough cryptomatte integration could solve all these problems *wink *wink
Could even create a bounty for it
Posted: Wed Oct 23, 2019 2:48 pm
Egert_Kanep wrote: Wed Oct 23, 2019 2:05 pm
So MATERIAL_ID_MASK AOV is probably what you are looking for
However you can get only one out of a single rendering.
Back to your original question: why background is a problem ? Isn't the same on the borderline of 2 different materials ? Do you just need a black background ?
Cryptomatte support is something worth adding.
Posted: Wed Oct 23, 2019 3:09 pm
by Egert_Kanep
Background should be black, yes. If I only use pure rgb colors in MATERIAL_ID_MASK AOV I get clean masks. White is problem because that contains all full rgb values, black doesn't and won't mess up the masks
Posted: Wed Oct 23, 2019 9:03 pm
Ok, I changed object and material ID for background to 0 (from 0xffffffff, aka white).
Posted: Wed Oct 23, 2019 9:29 pm
by Egert_Kanep
That's awesome news
