OpenCl renders 0 samples
Posted: Fri Oct 18, 2019 8:45 pm
by Egert_Kanep
I'm trying to render a scene, CPU path works and OpcenCl with cpu works. Opencl with only gpu renders 0 samples.
[LuxCore][671.109] [LinearToneMap] Compiling kernels
[LuxCore][671.109] [LinearToneMap] Kernels cached
[LuxCore][671.109] [LinearToneMap] Compiling LinearToneMap_Apply Kernel
[LuxCore][671.109] [LinearToneMap] Kernels compilation time: 0ms
[LuxCore][671.656] [GeForce GTX 965M Intersect] Memory used for OpenCL image pipeline: 40828Kbytes
[Engine/Final] Finished rendering layer "View Layer
usually when vram is full it says something, but looking a luxcore panel in blender I still had free memory so I have no idea what is going on. I'll try to make empty scene and appen all object to see if my file is at fault.
Re: OpenCl renders 0 samples
Posted: Fri Oct 18, 2019 9:16 pm
Do you have very long (eye) paths or very high image resolution ?
Posted: Fri Oct 18, 2019 9:25 pm
by Egert_Kanep
Image resolution was 1000x1300 and path depths are default.
Posted: Fri Oct 18, 2019 9:29 pm
Egert_Kanep wrote: Fri Oct 18, 2019 8:45 pm
It sounds like the GPU freeze if it works with OpenCL CPU but not with OpenCL GPU device.
Posted: Fri Oct 18, 2019 9:38 pm
by Egert_Kanep
So the gpu is just not ''beefy'' enough?
Posted: Fri Oct 18, 2019 9:54 pm
by Egert_Kanep
So I got it working with tiled rendering 64 pixel, super
Posted: Sat Oct 19, 2019 12:30 pm
Egert_Kanep wrote: Fri Oct 18, 2019 9:54 pm
Some (new) GPU use virtual memory and can swap their memory to the CPU memory however it is a very slow operation. Tile rendering can save a lot of memory for high resolution renderings, may be you were running out of physical GPU memory.
Posted: Sat Oct 19, 2019 1:32 pm
Dade wrote: Sat Oct 19, 2019 12:30 pm
This is not as simple as you make it sound. It won't just run out of memory and swap to system ram. I constantly keep running out of vram (8gb rtx2070) and instead of slow rendering I get no rendering on gpu and only lighttracing from cpu.(if lighttracing is enabled). I think opencl just fails to do anything if you run out of vram and only leaves cpu to do rendering which clearly looks weird if lighttracing is enabled.
I'm starting to think that modern gpus(nvidia) just don't play well with opencl...
Posted: Sat Oct 19, 2019 3:44 pm
lacilaci wrote: Sat Oct 19, 2019 1:32 pm
It does if you have an new AMD GPU.
Posted: Sat Oct 19, 2019 4:05 pm
Dade wrote: Sat Oct 19, 2019 3:44 pm
Is that a recomendation, or your idea of solution to the issue?
