Error - Maximum Recursion Depth Exceeded In Comparison
Posted: Fri Sep 13, 2019 2:54 pm
by Racleborg
What does this error message mean? 'Maximum Recursion Depth Exceeded In Comparison'
I'm loaded an old scene and this appears when switching to realistic viewport.
Thank you
Re: Error - Maximum Recursion Depth Exceeded In Comparison
Posted: Fri Sep 13, 2019 3:30 pm
Racleborg wrote: Fri Sep 13, 2019 2:54 pm
Is it a Blender message, console message ? A screenshot may help.
Posted: Fri Sep 13, 2019 3:40 pm
by Racleborg
Blender is now crashing as soon as I try and open the scene.
As soon as I see the message again I'll grab a console output. In fact, from now onwards I'll try and always get the console output before posting
Sorry.
Posted: Sat Sep 14, 2019 12:32 pm
by Racleborg
Console Output:
Read prefs: C:\Users\Racleborg\AppData\Roaming\Blender Foundation\Blender\2.80\config\userpref.blend
found bundled python: C:\Program Files\Blender Foundation\Blender\2.80\python
BlendLuxCore registered (2.2beta4)
archipack: ready
Read blend: D:\BLENDER\Studio from Stable\Room Challenge from Wifey\Promotional\Redish Fabric2 .blend
Updating OpenCL device list
Updated LuxCoreNodeTexImagemap node "Imagemap.001" in tree "Bottle Glass" to new version
Updated LuxCoreNodeTexImagemap node "Imagemap" in tree "Bottle Glass" to new version
Updated LuxCoreNodeTexImagemap node "Imagemap.002" in tree "Bottle Glass" to new version
Updated LuxCoreNodeTexImagemap node "Imagemap" in tree "Cushion Right Fabric.001" to new version
Updated LuxCoreNodeTexImagemap node "Imagemap.002" in tree "Cushion Right Fabric.001" to new version
Updated LuxCoreNodeTexImagemap node "Imagemap.001" in tree "Cushion Right Fabric.001" to new version
Updated LuxCoreNodeTexImagemap node "Imagemap" in tree "electric box" to new version
Updated LuxCoreNodeTexImagemap node "Imagemap" in tree "Fabric and Velvet .001" to new version
Updated LuxCoreNodeTexImagemap node "Imagemap.001" in tree "Finish.002" to new version
Updated LuxCoreNodeTexImagemap node "Imagemap" in tree "Floor_alt7.002" to new version
Updated LuxCoreNodeTexImagemap node "Imagemap.001" in tree "Floor_alt7.002" to new version
Updated LuxCoreNodeTexImagemap node "Imagemap" in tree "Floor_alt7.003" to new version
Updated LuxCoreNodeTexImagemap node "Imagemap.001" in tree "Floor_alt7.003" to new version
Updated LuxCoreNodeTexImagemap node "Imagemap" in tree "glass.BLUE" to new version
Updated LuxCoreNodeTexImagemap node "Imagemap.002" in tree "glass.BLUE" to new version
Updated LuxCoreNodeTexImagemap node "Imagemap.001" in tree "glass.BLUE" to new version
Updated LuxCoreNodeTexImagemap node "Imagemap" in tree "grill" to new version
Updated LuxCoreNodeTexImagemap node "Imagemap" in tree "HDRI" to new version
Updated LuxCoreNodeTexImagemap node "Imagemap" in tree "knobs" to new version
Updated LuxCoreNodeTexImagemap node "Imagemap" in tree "main box" to new version
Updated LuxCoreNodeTexImagemap node "Imagemap.001" in tree "main box" to new version
Updated LuxCoreNodeTexImagemap node "Imagemap.002" in tree "main box" to new version
Updated LuxCoreNodeTexImagemap node "Imagemap" in tree "main case" to new version
Updated LuxCoreNodeTexImagemap node "Imagemap.001" in tree "main part" to new version
Updated LuxCoreNodeTexImagemap node "Imagemap" in tree "mETAL FOOT PART.001" to new version
Updated LuxCoreNodeTexImagemap node "Imagemap" in tree "Piping.001" to new version
File "C:\Users\Racleborg\AppData\Roaming\Blender Foundation\Blender\2.80\scripts\addons\BlendLuxCore\handlers\load_post.py", line 48, in handler
compatibility.run()
File "C:\Users\Racleborg\AppData\Roaming\Blender Foundation\Blender\2.80\scripts\addons\BlendLuxCore\utils\compatibility.py", line 13, in run
update_output_nodes_volume_change(node_tree)
File "C:\Users\Racleborg\AppData\Roaming\Blender Foundation\Blender\2.80\scripts\addons\BlendLuxCore\utils\compatibility.py", line 37, in update_output_nodes_volume_change
for old_output in find_nodes(node_tree, "LuxCoreNodeMatOutput"):
File "C:\Users\Racleborg\AppData\Roaming\Blender Foundation\Blender\2.80\scripts\addons\BlendLuxCore\utils\node.py", line 134, in find_nodes
result += find_nodes(node.node_tree, bl_idname)
[Previous line repeated 992 more times]
File "C:\Users\Racleborg\AppData\Roaming\Blender Foundation\Blender\2.80\scripts\addons\BlendLuxCore\utils\node.py", line 133, in find_nodes
if node.bl_idname == "LuxCoreNodeTreePointer" and node.node_tree:
RecursionError: maximum recursion depth exceeded in comparison
[Engine/Viewport] New session
[Exporter] Creating session
ERROR: maximum recursion depth exceeded in comparison
File "C:\Users\Racleborg\AppData\Roaming\Blender Foundation\Blender\2.80\scripts\addons\BlendLuxCore\engine\viewport.py", line 44, in view_update
engine.session = engine.exporter.create_session(depsgraph, context, engine=engine)
File "C:\Users\Racleborg\AppData\Roaming\Blender Foundation\Blender\2.80\scripts\addons\BlendLuxCore\export\__init__.py", line 89, in create_session
utils_compatibility.run()
[Previous line repeated 990 more times]
new framebuffer
Thanks
Posted: Sat Sep 14, 2019 12:41 pm
It looks like there's a dependency cycle in some of the node trees:
In node tree A, there's a material output pointing to a volume node tree B, which itself contains a pointer node to A. This leads to infinite recursion when traversing the tree.
At least that's my theory, can you upload the file?
Posted: Sat Sep 14, 2019 12:45 pm
by Racleborg
'BYOB
The scene is quite large (295mb) so I'll look for the points you mentioned, and if no joy I'll start stripping the scene down to upload.
Thanks
Posted: Sat Sep 14, 2019 12:48 pm
You could also open this file with a text editor:
https://github.com/LuxCoreRender/BlendL ... ity.py#L36
In the highlighted line (36), add the following code:
print("Updating tree:", node_tree.name)
Then when the error is thrown, you'll find out what the name of the offending node tree is and you can check it in detail.
Posted: Sat Sep 14, 2019 1:07 pm
by Racleborg
by B.Y.O.B. ยป Sat Sep 14, 2019 1:48 pm
That is so cool! After my initial panic of how to do this
it is now working and throwing out what appears to be quite a few errors.
Many thanks and when I've nailed down the problem I'll repot back
Posted: Sat Sep 14, 2019 6:43 pm
by Racleborg
I hav'nt been able to find the exact problem. In fact, even after deleting all objects that appeared to contain errors, I was still getting the same errors.
So, I (CTR-A) copied and pasted everything into a new project and it's now ok.
Posted: Sat Sep 14, 2019 7:03 pm
I think you would have to delete the node trees (or at least the nodes that cause the cycle).
