Luxcore denoiser VS denoise node in blender 2.81
Posted: Sun Sep 01, 2019 4:43 pm
by Rivental1
I have tested denoise node in blender 2.81 with luxcore, end get more clenear result than with native denoiser.
- Without denoiser
- Luxcore denoiser
- Denoise node in blender 2.81
As you see, cube with only diffuse mate, is clean in both examples. But volumetric sphere is more cleaner with denoise node... Maybe i do something wrone with luxcore denoiser, but i see only one checbox on menu and that all). In denoise node i did not use albedo or normal pass. It thinked both denoisers it is intel denoiser, so they have to give same results. Or not? Picture after 30 samples.
Re: Luxcore denoiser VS denoise node in blender 2.81
Posted: Sun Sep 01, 2019 4:51 pm
In BlendLuxCore we currently always use Albedo and Avg. Shading Normal AOVs as additional denoiser inputs.
This is most likely the explanation for your results: glass can cause noise in the Albedo AOV, which causes those areas to be insufficiently denoised. When the Albedo AOV is not used, the overall result can be a bit worse, but you circumvent the glass problem.
I can make albedo/normal AOVs optional in BlendLuxCore, however a better solution would be to somehow get a clean Albedo AOV for glass materials.
Posted: Sun Sep 01, 2019 5:01 pm
by Rivental1
Thank you for the fast reply!!!
Posted: Sun Sep 01, 2019 5:05 pm
B.Y.O.B. wrote: Sun Sep 01, 2019 4:51 pm
...a better solution would be to somehow get a clean Albedo AOV for glass materials.
^^ this
