				Volumes for Fire and Smoke
				Posted: Wed Aug 28, 2019 8:23 pm
				by Racleborg
				I'd like to create a living room type fire (and smoke)
I can do it in Cycles, but can't work out how to do it correctly in Lux.
Could someone please upload a basic node setup or scene for me to learn from?
Many thanks
				Re: Volumes for Fire and Smoke
				Posted: Wed Aug 28, 2019 8:41 pm
				by FarbigeWelt
				Racleborg wrote: Wed Aug 28, 2019 8:23 pm
Many thanks
Did you read and follow B.Y.O.B‘s
post already?
				Posted: Wed Aug 28, 2019 10:07 pm
				by Racleborg
				Did you read and follow B.Y.O.B‘s post already?
No, I hadn't seen that.
That's great and very helpful.
Thank you
				Posted: Thu Aug 29, 2019 7:32 am
				by Racleborg
				.........so, if the Emitter is setup for FIRE + SMOKE can I separate these two in the SMOKE DATA node as it only gives option for FIRE, HEAT, COLOR, DENSITY and VELOCITY? or do I need to do something else?
Thanks
				Posted: Thu Aug 29, 2019 8:18 am
				by Racleborg
				Oops, sorry for wasting time
  When both fire and smoke is selected the colour is different for each. (I'm fairly sure that's correct)
				Posted: Fri Aug 30, 2019 5:31 pm
				There is a node tree preset for "Fire and Smoke" available in the material properties, apply it to the domain material to have a starting point.
				Posted: Sat Aug 31, 2019 10:32 am
				by Racleborg
				Thanks. Found it!
 I wasn't looking in the right place. Like the Disney Shader I think?
It's not where I normally add materials from. (I don't know the name of all the UI areas so I've attached an image.
				Posted: Sat Aug 31, 2019 10:42 am
				The missing disney has been fixed.
				Posted: Sat Aug 31, 2019 10:48 am
				by Racleborg
				Thank you
