Denoiser on animation renders
Posted: Mon Aug 26, 2019 10:02 pm
by aidalgol
How to I specify saving the denoised renders when rendering an image sequence? I have the image viewer to show the "DENOISED" render, but the files saved to disk are clearly the pre-denoised renders. I am using Blender 2.79 with LuxCore 2.2beta3.
Re: Denoiser on animation renders
Posted: Mon Aug 26, 2019 10:38 pm
by Racleborg
I set mine up in the compositor and decide what percentage to have as Denoised.
(image attached)
I don't know for sure that this is the normal way......but hope it helps.
Posted: Tue Aug 27, 2019 12:19 am
by aidalgol
Using the compositor with the DENOISED output to the Composite node seems to work, so yes, that helps. Thanks!
But... why do you mix the noisy and denoised renders?
Posted: Tue Aug 27, 2019 5:26 am
by Racleborg
Post
by aidalgol » Tue Aug 27, 2019 1:19 am
It may just be a matter of personal taste, but If I'm using a low sample count and the denoise looks a bit splodgy then mixing in a bit of the un-denoised can help a bit. And, within reason, I quite like a bit of noise/grain in the renders.
Posted: Tue Aug 27, 2019 8:42 am
aidalgol wrote: Tue Aug 27, 2019 12:19 am Using the compositor with the DENOISED output to the Composite node seems to work, so yes, that helps. Thanks!
I agree with Racleborg‘s opinion. Additionally the more sample counts the less noise and the less mix has any influence. And yet another fact, low sample counts even if quite noiseless might lose details with denoiser. Depending on individual taste mix ratio between 0.5 and 0.95 makes sense, I often use 0.85 for denoised image, means 0.15 parts of raw image.
Posted: Tue Aug 27, 2019 10:55 am
by Racleborg
That's about the same values that I use.
