				Reworked Direct Light Sampling Cache (aka DLSC)
				Posted: Thu Aug 22, 2019 9:20 am
				I have reworked the Direct Light Sampling Cache (DLSC), based on the experience developed with other caches, it should be now faster, artifacts free and fully unbiased.
This is a 64 samples/pixel rendering without DLSC:
and this with:
Like some other cache, it can show different noise patterns at the very beginning of the rendering. This is a 8 samples/pixel rendering with DLSC:
and this at 128 samples/pixel:
As you can see, the not uniform noise disappear with more samples (i.e. it is unbiased). If you have some really huge noise difference at the start, it is a signal the cache entries are quite inaccurate, just increase the warm up samples to solve the problem. Note, the Blender default warm up value may be too low at the moment, 24-32 should be the bare minimum.
For Reference this is a 8 samples/pixel rendering without DLSC:
The improvement is really huge.
				Re: Reworked Direct Light Sampling Cache (aka DLSC)
				Posted: Thu Aug 22, 2019 9:33 am
				by Racleborg
				Wow! The difference is really impressive. Thank you
				Posted: Thu Aug 22, 2019 9:36 am
				by happyboy
				Wow! Waiting for the new build to test
				Posted: Thu Aug 22, 2019 9:37 am
				by marcatore
				oh- oh-oh... is it already available?
I'd like to see a comparison with the previous DLSC... have you something to show in this way?
In any case it seems really a great improvement.
				Posted: Thu Aug 22, 2019 10:46 am
				Thanks you and good job !
How about the cache pre-computing time ? and also how much setting user need to tweak compared to older cache ?
				Posted: Thu Aug 22, 2019 10:47 am
				marcatore wrote: Thu Aug 22, 2019 9:37 am
The binaries should be available in a couple of hours.
The main problem of the original DLSC was more about artifacts and consistency in providing good results than delivering a really good result (once in a while). The new version may produced renderings with a bit more noise of the original DLSC (especially in some test case) but the rework focus was on fixing artifacts and consistency (more then further reducing noise).
				Posted: Thu Aug 22, 2019 10:50 am
				Sharlybg wrote: Thu Aug 22, 2019 10:46 am
It should be faster than the original DLSC because several steps have been removed but the main job of establishing how a much a point is in shadow, it is still there (and it is still an expansive task).
I'm also  going to add a persistent fill option for this cache too (... if I haven't already added ... I don't remember).
Like other caches, it should work without parameters tweaking.
				Posted: Thu Aug 22, 2019 12:31 pm
				by Asticles
				Amazing! Is this available in the nightly builds?
				Posted: Thu Aug 22, 2019 12:48 pm
				Asticles wrote: Thu Aug 22, 2019 12:31 pm
you can watch it cooking here:
https://dev.azure.com/LuxCoreRender/Lux ... uildId=661
but keep in mind that even when it says it's all done, uploading to dailies might take a while longer...
				Posted: Thu Aug 22, 2019 1:04 pm
				by marcatore
				Available!
