cannot activate addon
Posted: Wed Aug 21, 2019 9:09 am
by youamer
i am not able to activate the blender addon. kindly check attachments
Re: cannot activate addon
Posted: Wed Aug 21, 2019 10:12 am
youamer wrote: Wed Aug 21, 2019 9:09 am
There may be several reasons why it happens:
- have you installed the "Microsoft Visual C++ Redistributable for Visual Studio 2017" ?
- are you trying to use an OpenCL-enabled version without having OpenCL drivers installed ? Does LuxMark work ?
- are you using a different Blender version from the one supported ? It must be the official v2.79b.
Posted: Thu Aug 22, 2019 5:13 am
by youamer
I downloaded the beta one for blender 2.8 and it is working fine so I think the dependencies are ok.
I tried both with and without opencl
I am not sure about the official blender release. the screenshot has a small part in the upper right corner showing the blender release from the splash screen
Posted: Thu Aug 22, 2019 6:47 am
youamer wrote: Thu Aug 22, 2019 5:13 am
Yup.
Do you have problems with LuxCoreRender v2.1 or the v2.2beta3 ? The problem is likely to be the Blender version, for instance, if you are using a buildbot Blender binaries, they will not work.
Otherwise, it could be some kind of addon conflict, do you have AMD ProRender installed/enabled ? You should try with a fresh Blender v2.79b installation.
Posted: Fri Aug 30, 2019 5:41 pm
Looks like you use a 2.79 buildbot build, those are not supported.
