First render luxcore
Posted: Tue Aug 20, 2019 4:15 pm
First luxcore render, second interior render ever. I plan to use Davinci to add some color grades and such later. Can i get some pointers and strong criticism people?
4 hours is a lot. Caching meaning photongi cache? If you enable indirect cache you get BSOD?eddlad wrote: Tue Aug 20, 2019 5:13 pm Yeah sure, i will check that. How long do you think it should have taken?( took 4hours on my laptop hardware, i7 6500u with 950gtx). Also i notice you are not new so maybe i can ask this, might you have an idea as to why during caching the system freezes up and goes to ''blue screen''?
Yes photongi cache and yes indirect cache is actually on by default. I did check the settings again and made another render unchecking the intel graphic card in my gpu list( leaving the gtx950 option) and the freezing seem to stop, i think. With regard to the render time do you think @2000 makes it okay for 4hours? I tried lower but the blurring from the denoiser was messing with the already not so good leather i had going onlacilaci wrote: Tue Aug 20, 2019 6:07 pm4 hours is a lot. Caching meaning photongi cache? If you enable indirect cache you get BSOD?eddlad wrote: Tue Aug 20, 2019 5:13 pm Yeah sure, i will check that. How long do you think it should have taken?( took 4hours on my laptop hardware, i7 6500u with 950gtx). Also i notice you are not new so maybe i can ask this, might you have an idea as to why during caching the system freezes up and goes to ''blue screen''?
Ah yes, integrated gpus always cause trouble. What version of luxcore did you useeddlad wrote: Tue Aug 20, 2019 7:56 pmYes photongi cache and yes indirect cache is actually on by default. I did check the settings again and made another render unchecking the intel graphic card in my gpu list( leaving the gtx950 option) and the freezing seem to stop, i think. With regard to the render time do you think @2000 makes it okay for 4hours? I tried lower but the blurring from the denoiser was messing with the already not so good leather i had going onlacilaci wrote: Tue Aug 20, 2019 6:07 pm4 hours is a lot. Caching meaning photongi cache? If you enable indirect cache you get BSOD?eddlad wrote: Tue Aug 20, 2019 5:13 pm Yeah sure, i will check that. How long do you think it should have taken?( took 4hours on my laptop hardware, i7 6500u with 950gtx). Also i notice you are not new so maybe i can ask this, might you have an idea as to why during caching the system freezes up and goes to ''blue screen''?![]()
I got it from this page viewtopic.php?f=9&t=1287 this link to be specific: https://github.com/LuxCoreRender/BlendL ... OpenCL.ziplacilaci wrote: Wed Aug 21, 2019 4:51 amAh yes, integrated gpus always cause trouble. What version of luxcore did you useeddlad wrote: Tue Aug 20, 2019 7:56 pmYes photongi cache and yes indirect cache is actually on by default. I did check the settings again and made another render unchecking the intel graphic card in my gpu list( leaving the gtx950 option) and the freezing seem to stop, i think. With regard to the render time do you think @2000 makes it okay for 4hours? I tried lower but the blurring from the denoiser was messing with the already not so good leather i had going onlacilaci wrote: Tue Aug 20, 2019 6:07 pm
4 hours is a lot. Caching meaning photongi cache? If you enable indirect cache you get BSOD?![]()
Thank you for the notes, i will keep it in mind.Sharlybg wrote: Wed Aug 21, 2019 7:23 pm Very nice indeed for a first render.
You can improve it by making light more contrasted. add a bit of shadow depth or mix natural + artificial light. also try to follow a good reference :
