long triangles
Posted: Mon Aug 19, 2019 8:36 am
This keeps coming back again and again.
opencl
cpu
even on cpu some very thin and long triangles show up black! It's just that opencl is more sensitive to the issue... It almost looks like some overlapping is happening..
raising min epsilon won't help and main scene contains volumes so even if it helped it might give me problems with volumes..
scene
triangles.blend
(626.29 KiB) Downloaded 191 times
note:
In this particular case I know how to fix stairs, but the back wall would need more work and I've been given CAD files from people where I cannot simply tell them how to tesselate meshes so that luxcore doesn't have issues with it, so it can easily turn into unsolvable problem.
And even when I have option to tesselate meshes on my own it requires a trial and error
tesselated stairs
Re: long triangles
Posted: Mon Aug 19, 2019 8:48 am
by Racleborg
I use this to help fix imported CAD (stl) files. It works quite well. I hope it helps :)
https://github.com/wjakob/instant-meshes
Re: long triangles
Posted: Mon Aug 19, 2019 9:20 am
Racleborg wrote: Mon Aug 19, 2019 8:48 am I use this to help fix imported CAD (stl) files. It works quite well. I hope it helps :)
Thanks... but this is a bug and needs fixing.
Re: long triangles
Posted: Tue Aug 20, 2019 8:54 am
small triangles can make luxcore flip out too...
and if I move camera closer they tend to disappear :shock: changing min. epsilon isn't helping
Re: long triangles
Posted: Tue Aug 20, 2019 9:37 am
please can we see a wireframe of the same view ?
Re: long triangles
Posted: Tue Aug 20, 2019 9:51 am
Sharlybg wrote: Tue Aug 20, 2019 9:37 am please can we see a wireframe of the same view ?
I don't know what you hope to gather from that but here you go
Re: long triangles
Posted: Tue Aug 20, 2019 11:08 am
by Fox
Bevel modifier???
See if you apply it, are there any weird overlappings or onmanifold edges.
Re: long triangles
Posted: Tue Aug 20, 2019 11:49 am
There are no modifiers, and no custom shading and no overlapping faces...
Mesh has coumple ngons, but it doesn't matter if I triangulate it manually...
Also the defect changes with angle of camera sometimes it seems
Let me make one thing clear. I know how to fix this or the stairs mesh scene I posted if I really want cause these are my meshes... But:
A: I can't always fix this
B: Even when it can be fixed it is sometimes a lot of extra work that's usually not needed with other renderers
C: Issue is also present in cpu rendering but a less visible sometimes
Re: long triangles
Posted: Tue Aug 20, 2019 1:43 pm
lacilaci wrote: Mon Aug 19, 2019 8:36 am This keeps coming back again and again.
opencl
cpu
It looks like a different problems (if there is a problem), if I just disable bump mapping on the used Disney material (or replace the material with a plain white matte), I get a good rendering, both on CPU and OpenCL:
So, it is not the geometry problem you are talking about. I don't know how the bump was intended to affect the rendering (or if it was intended at all) so I'm not sure if there is a problem at all.
Do you have a different test scene where the problem is really related only to the geometry ?
Re: long triangles
Posted: Tue Aug 20, 2019 1:56 pm
Dade wrote: Tue Aug 20, 2019 1:43 pm
opencl
cpu
Oh shit, you are correct... This was happening cause there was missing UV map on those meshes...
If mesh has uv's it all works fine. I keep forgetting that it is a problem in luxcore.
no uv map:
with uv map:
