Page 1 of 3
distant light vs sunlight
Posted: Tue Aug 06, 2019 7:07 am
distant light doesn't produce caustics, only sun does
distant:
sunlight:
Since we don't have direct control over sunlight in luxcore I would have to rely on postprocessing whitebalancing. We either need direct control over color or temperature on sun or make distant light act in the same way as sun (so that it can do caustics)
Re: distant light vs sunlight
Posted: Tue Aug 06, 2019 8:41 am
lacilaci wrote: Tue Aug 06, 2019 7:07 am
Yes, this is normal: distant light is a not intersectable light source (i.e. all parallel rays coming for a direction) while sun is intersectable (i.e. a very far and small bright disk , the "relsize" parameter can be used to artificially increase the disk size and make caustics easier to render). They are two quite different types of light sources.
Posted: Tue Aug 06, 2019 10:06 am
Dade wrote: Tue Aug 06, 2019 8:41 am
Does this mean one can replace sun by a circle faced object? But then one gets a number of lights equal the number of triangles of the circle area.
What would be the amount of work to implement a round area light, intersectable in this case not like the (round) laser?
What is the amount of work if this round area light (with light count 1) can be set to blackbody temperature color?
Posted: Tue Aug 06, 2019 10:07 am
I think distant light should work like sun (intersectable disc) just with proper full color controls
Posted: Tue Aug 06, 2019 10:20 am
lacilaci wrote: Tue Aug 06, 2019 10:07 am
You normally don't need that. normal sun + gain color just do the Job. any color any mood any shadow sharpness is possible with it.
Yes changing angle make sun color warmer or colder but it is easy to fix that with gain color in less than a second.
Posted: Tue Aug 06, 2019 10:26 am
FarbigeWelt wrote: Tue Aug 06, 2019 10:06 am
No, because a circle shaped meshlight won't emit parallel light rays over the whole scene.
Posted: Tue Aug 06, 2019 10:29 am
Sharlybg wrote: Tue Aug 06, 2019 10:20 am
does this look like a blue sun to you?:
no, sun color is right now some sort of counterbalance to actual sun color which depends on it's angle... this is as counter intuitive as it gets imho...
Posted: Tue Aug 06, 2019 10:48 am
"If it looks like a duck, swims like a duck, and quacks like a duck, then it probably is a duck.": it is pointless to have 2 light sources that work in the same way.
The source of your problem is not being able to use textures in light source parameters. With old Lux it was possible and using the blackbody texture for light source gain/color, I think it is what you are looking for.
There are various way to address this problem:
1) add texture support for light source parameters;
2) add some specific support to LuxCore express gain/color with temperature/etc.
3) add some specific support to BlendLuxCore express gain/color with temperature/etc (it is a static transformation from color to color values).
They are all viable but we must stop adding new features to v2.2 or it is never going to be finished. I'm working on shadow terminator problem, than I have a pending DLSC rework and it is done. After that, only bug fixes.
Posted: Tue Aug 06, 2019 10:52 am
Dade wrote: Tue Aug 06, 2019 10:48 am
I absolutely agree, I also agree that my problem could be solved by having direct color control over sun...
But I also have to ask... what is the purpose of distant light?
Posted: Tue Aug 06, 2019 11:01 am
From user perspective this could be solved in 2 ways.
1.make distant light literally the same as sunlight but give a direct color control over light.
2.get rid of distant light and give user a checkbox saying "direct light control" enabling color controls.
having distant light is pointless as long as it's non intersectible and you have to use crazy values to turn it into substitute of sun(which you never really can cause it won't cast caustics)... Unless there is a specific reason that I'm not aware of why this even exists..
