bidir vs pathocl Shading
Posted: Tue Aug 06, 2019 6:49 am
I've got some weird gradients going on with bidir, note the part on the top of the image...
bidir:
pathOCL:
blender file:
shading_issue.blend
(1.84 MiB) Downloaded 150 times
Re: bidir vs pathocl Shading
Posted: Tue Aug 06, 2019 7:06 am
lacilaci wrote: Tue Aug 06, 2019 6:49 am I've got some weird gradients going on with bidir, note the part on the top of the image...
bidir:
pathOCL:
blender file:
shading_issue.blend
I have no access to my PC at the moment and cannot look at the object. This is why I ask a few questions.
Is the object smooth or flat shaded?
Do you see a gradient in solid openGL preview in viewport too?
If yes you can avoid this. Extrude top surface in edit mode. Move extruded surface a short way upwards (z-axis) just so that you can distinct vertices in top corners. The openGL shading should be uniform now. The render will be too.
Posted: Tue Aug 06, 2019 7:12 am
FarbigeWelt wrote: Tue Aug 06, 2019 7:06 am
bidir:
pathOCL:
blender file:
shading_issue.blend
Thanks, I'm aware how shading works. It would be kinda weird if I didn't by now :D it would also look the same in OCL rendering as in bidir if that was the case...
It's a simple flat plane, tried reseting normals, smoothing, flattening normals, reversing normals... and idk what else..
Posted: Tue Aug 06, 2019 8:44 am
I'm aware of this problem but I have yet to investigate the source, it must be something in MIS weights.
Posted: Tue Aug 06, 2019 9:21 am
Is there some ETA on this? I need caustics(POOL) for my next project that means only bidir+metro+LOT of rendertime...
For me that means either bidir+metro but there is this shading issue, or wait until lighttracing gets vertex merging, not sure which will come sooner and my only other option is fake caustics+cycles and I really don't want to go back to cycles now that 2.8 will have luxcore addon...
Posted: Tue Aug 06, 2019 9:48 am
lacilaci wrote: Tue Aug 06, 2019 7:12 am
Actually I did not expect anything else from someone with experienced skills. 😃 But even close to perfection people forget sometimes the simplest things.
However, until yesterday I thought to know how Blender deals with surfaces and shading. What was that of an error! I have to post my latest observations this evening maybe someone of the forum has the explanations. There must be some hidden parameters of a triangle‘s surface which are independent on vertices and surface normal and these parameters are responsible for different smooth shading tones. :!: :?: :!:
Posted: Tue Aug 06, 2019 9:57 am
FarbigeWelt wrote: Tue Aug 06, 2019 9:48 am
I have a feeling that you might have ran into a problem of custom normals in blender, where these are often not exported to luxcore and cause a LOT of trouble especially when you use CAD models or create custom breaks of normals in blender... very annoying but it just might be a blender bug/problem
