Semi Classic Bedroom
Posted: Thu Jul 18, 2019 6:18 am
by giri_dc
Hi All,
Here is my first project using LuxCoreRender. Great render engine!
Software used:
Modelling : Google Sketchup 8
Rendering : Blender 2.79b + LuxCoreRender v2.2 beta 2
Post-production : Affinity Photo
Resolution : 1920 x 1080 px
Samples : 500
Rendering time : 27 minutes (CPU path, i've tried openCL but crashed
Hardware : Core i7 4750 + Nvidia GTX 950
https://www.behance.net/gallery/8304263 ... ic-Bedroom
Hope you like it!
Re: Semi Classic Bedroom
Posted: Thu Jul 18, 2019 6:23 am
nice!
giri_dc wrote: Thu Jul 18, 2019 6:18 am
Did you disable the integrated intel gpu when rendering with opencl? I think it's enabled by default and it causes trouble.
I think there should be some auto-check and disable every integrated gpu and luxcore should list and enable only discrete gpus.
Posted: Thu Jul 18, 2019 8:46 am
Well executed ! like it isn't your first lux try.
Can you share a bit more about your workflow.
Clamping setting/ Photon_GI/ lighting.
Posted: Fri Jul 19, 2019 8:10 am
by Racleborg
I don't often see work done in Sketchup that I like - I think that they generally appear to be too stiff. But I like your images - good stuff!
Posted: Sun Jul 21, 2019 9:25 am
by giri_dc
lacilaci wrote: Thu Jul 18, 2019 6:23 am
nice!
Thanks @lacilaci,
i've enabled "gpu's performance only" and my scene can't stop when rendering process on 100% (for example, i set rendering time = 5 minutes and then error/not responding when i cancel this process)
is this my hardware problem or minimum requirement limitation?
*sorry for my english
Posted: Sun Jul 21, 2019 9:40 am
by giri_dc
Sharlybg wrote: Thu Jul 18, 2019 8:46 am
Thanks a lot @Sharlybg ,
Your photorealistic visualization was inspired me,
About my workflow, nothing special.
All settings was imitated from benchmark scene (with little bit tweaking)
about lighting, i used skylight and sun only for daylight scene,
and for evening scene, i used skylight (dark blue color w/ low intensity) and area light which directed to windows for more dark blue light.
Posted: Sun Jul 21, 2019 9:41 am
by giri_dc
Racleborg wrote: Fri Jul 19, 2019 8:10 am
Thanks @Racleborg
Posted: Sun Jul 21, 2019 9:48 am
giri_dc wrote: Sun Jul 21, 2019 9:25 am
Any error messages in the console? (Window -> Toggle System Console)
Can you send me the scene?
Posted: Sun Jul 21, 2019 11:49 am
by giri_dc
Finally my problem has solved.
i just see that the "GPU Devices tab" is shown if we enable OpenCl at Luxcore Config
The rendering time now is just 11 minutes 45 seconds. Thanks @Lacilaci and @B.Y.O.B.
