crash after about 4 minutes of rendering
Posted: Sun Jun 16, 2019 1:18 pm
I get an crash after about 4 minutes of rendering with Blender 2.79b and Luxcore 2.1
I use a panoramic camera with 1920x1080 resolution for my scene of a biological experiment where fish is sitting in the center of a sphere, which serves as an optical stimulus for the fish.
1. When I render with 50% resolution the image renders fine and the rendering finishes after 3:39 minutes and 500/500 samples.
2. When I render with 100% resolution the render process crashes hard at about 4:30 minutes and 180/500 samples and the laptop shuts down imediatly.
In the first case it works despite the warning "The scene contains a lot of light sources (262145), performance might suffer". I guess that adresses my optical stimulus that is a sphere with an UV-Map and emitting material.
In the second case after restart of the laptop the render engine "LuxCore" is missinging in the standard start window of blender (with the cube) . But it is still listed and activated in the user preverences add-ons.
- when I deactivate it and activate it again then I get an error message (s. below)
- when I install the add-on from file again the render engine shows back again and is working.
