Why is image with PGIC darker than without?
Posted: Tue Jun 11, 2019 4:58 pm
LuxCoreRender 2.2 beta 1, build 004d2aa
Today, I noticed there can be a big difference in color and brightness if PGIC is enabled compared to disabled.
Please look at the image, they have both the same fixed tone map settings (Reinard).
Why is the render darker with PGIC? What happens to the energy?
Organic Figurines openCL 769 samples OIDN 0.85
Organic Figurines openCL PGIC 752 samples OIDN 0.85
Talking about Reinard ... Did anyone else notice that preview in viewport and final render do not have the same brightness?
Why does Reinard take some dozen samples to stabilize its brightness?
Re: Why is image with PGIC darker than without?
Posted: Tue Jun 11, 2019 9:49 pm
Without any information about material types,light sources, cache type and/or a test scene, it is hard to say.
FarbigeWelt wrote: Tue Jun 11, 2019 4:58 pm they have both the same fixed tone map settings (Reinard).
Have you tried with linear tone mapping ? Reinard is dynamic like auto linear tone mapping.
Posted: Wed Jun 12, 2019 8:42 am
Dade wrote: Tue Jun 11, 2019 9:49 pm Without any information about material types,light sources, cache type and/or a test scene, it is hard to say.
I did not know that Reinard is dynamic too. Best is in this case to re-render with linear but without auto brightness.
The materials are a mix of glass 95% and matte 5%.
There are three area lights and the sun with sky.
Posted: Wed Jun 12, 2019 8:08 pm
Please have a look at the attached scene.
Organic Figurine.zip
Organic Figurine
(3.41 MiB) Downloaded 894 times
Meanwhile yes, please have a look at the two pictures. Objects are darker with PGIC, indirect plus caustic cache, than without. Sky background seems to have the same brightness.
Organic Figurine, openCL, indir and caustic cache, tone map
Organic Figurine, openCL, no cache, tone map linear fixed
Do you have any ideas why PGIC is darker?
Posted: Wed Jun 12, 2019 11:38 pm
by zeealpal
Have you tried increasing the depth of PGI?
On phone now, but IIRC that was a property. Your problem looks like glass with a too small path depth
Posted: Thu Jun 13, 2019 8:53 am
The problem is present only in GPU rendering, you get the same brightness on CPU. I will check what is going wrong.
Posted: Thu Jun 13, 2019 11:24 am
It is a damn AMD compiler bug, the same code works fine with NVIDIA GPU. I have tracked down the problem and the AMD code just doesn't write a value to the requested location; I will try to find a workaround but it may be not even possible.
Posted: Thu Jun 13, 2019 11:28 am
Dade wrote: Thu Jun 13, 2019 11:24 am It is a damn AMD compiler bug, the same code works fine with NVIDIA GPU. I have tracked down the problem and the AMD code just doesn't write a value to the requested location; I will try to find a workaround but it may be not even possible.
Why AMD driver seem to encounter so much little issue while being opencl only compute oriented while nvidia do both cuda/opencl and seem to work seamlessly ?
Posted: Thu Jun 13, 2019 11:50 am
The Nvidia compiler has its fair shair of problems as well ...
Posted: Fri Jun 14, 2019 9:04 am
Dade wrote: Thu Jun 13, 2019 11:24 am I will try to find a workaround but it may be not even possible.
I have found a ways to workaround the problem and now the scene should work fine on AMD GPUs too.
