Re: Disney BRDF material
Posted: Sat Jun 08, 2019 1:53 pm
I should have fixed the use of Disney material with PhotonGI.
Works great, thanks!
Umm, the specular value is always at 0.5 so it will always generate reflective caustics.
that specular value is a generic dielectric reflectance, Dade meant specular material as in refractive, this is where specular caustics could be cached (glass, body of water) I don't think caustic cache is capable of doing reflective caustics cause that would literaly mean creating cache for every single glossy material(maybe a threshold value could help, but would also impose limitations). So this is also why I don't think caching caustics is a way to go, since it only means specular caustics and even there we see quite a limitation. I might be wrong though....epilectrolytics wrote: ↑Sun Jun 09, 2019 2:36 pmUmm, the specular value is always at 0.5 so it will always generate reflective caustics.
And with metallic=1 and roughness=0 it is a perfect mirror material.
I think Disney, metal and glossy should work with caustic cache in the range of 0>0.2 roughness (that would be 0.45 for Disney because of its different roughness calculation).
