lxs file halttime[SOLVED]
Posted: Sat Apr 06, 2019 11:06 am
halttime doesn't seem to work in lxs files using the luxcoreconsole
filename also seems to be ignored but may its because halttime is being overlooked
I got around the problem by doing:
ut that doesn't solve the infile problem
"integer halttime" [1]
"string filename" ["_Material1"]Code: Select all
"C:\luxcorerender/luxcoreconsole.exe" -d "C:/Users/nige/AppData/Roaming/LuxRender/" " _Material1.lxs" -D "batch.halttime" "2"
