				Compiling an application to use LuxCore API
				Posted: Sun Mar 31, 2019 11:59 am
				by TAO
				I tried to reconfigure project to work with new luxcore API and also the new version of 3dsmax and VS, but they're so many errors.
So, I need some information here, is there any change LIB in the original project, for example, Embree.lib to Embree3 or removing fftw3.lib ?
And where I can find information about this kind of change?
Thank you for your help.
Also, should I ask these questions on this thread or other threads?
				Re: LuxCoreRender Project wants you!
				Posted: Sun Mar 31, 2019 12:25 pm
				by TAO
				I replace lib and dependencies as much as I can but I get new external symbol errors like this one, any idea?
Severity	Code	Description	Project	File	Line	Suppression State
Error	LNK2001	unresolved external symbol __imp_oidnSetSharedFilterImage	LuxMax	\MaxLuxCore\slg-film.lib(intel_oidn.obj)	1
or
Error	LNK2001	unresolved external symbol "class luxrays::Properties __cdecl luxrays::operator<<(class luxrays::Property const &,class luxrays::Property const &)" (??6luxrays@@YA?AVProperties@0@AEBVProperty@0@0@Z)	MaxLuxCore	\MaxLuxCore\MaxLuxCoreMesh.obj	1
				Re: Compiling an application to use LuxCore API
				Posted: Sun Mar 31, 2019 5:54 pm
				First step, what procedure are you using to compile LuxCore ? Are you using the one described at
https://github.com/LuxCoreRender/WindowsCompile ?
It may be better for you to use the "SDK" version (i.e. LuxCore compile as DLL so there are no dependencies).
Just run the following commands to compile the "SDK" version:
cd C:\Path\to\luxcorerender\WindowsCompile\
.\cmake-build-x64.bat /dll
create-sdk.bat
To use the "SDK" version in an app, you need only to add "#include  <luxcore/luxcore.h>" to you source and to link luxcore.lib, no other dependecy should be required.
				Posted: Sun Mar 31, 2019 6:26 pm
				by TAO
				LuxCore, Luxray, Slg-core, Slg-Film, Slg-Kernel build perfectly with no issue.
Most part off plugins fixed now and i can build it, the only remaining part is the part that needs luxcore.
I think There is something change in dependencies or LIBs maybe.
				Posted: Sun Mar 31, 2019 7:56 pm
				TAO wrote: Sun Mar 31, 2019 6:26 pm
But are you using the script ? What error do you get ?
				Posted: Sun Mar 31, 2019 8:33 pm
				by TAO
				I found the issues, now it's working.
It was so many changes since the last update especially in 3dsmax SDK and of course luxcore.
Finally, i manage to fix it so i can compile the code and see what's happening next.
