Page 8 of 67
Re: MaxLuxCore - 3ds Max Integration for LuxCore
Posted: Wed Sep 25, 2019 6:30 am
by TAO
I figure it out that intel OpenCL and Nvidia OpenCL won't work together and only one of them can be installed.
So as Dade mentioned, i uninstall Intel OpenCL and now i can see GPU OpenCL device in LuxMark, But the bad news is i faced a new issue in LuxCore when i try to render that i think related to no OpenCL device found issue.
- Annotation 2019-09-25 095021.png (4.85 KiB) Viewed 9079 times
I do not have any issue with AMD GPU or Intel OpenCL device (when the driver is installed).
Posted: Wed Sep 25, 2019 10:26 am
by TAO
Reinstalling the Nvidia driver did not solve the issue, none of the drivers that i download from Nvidia website worked, i remove the driver and install the driver from Microsoft update services (v431.70), it's a little bit older than last Nvidia driver (v436), but works for me and now, i can use both CPU and GPU OpenCL in LuxMark at the same time.
On the other hand, unfortunately, GetOpenCLDeviceDescs() function still returns just one platform and LuxCore plugin can not use Nvidia OpenCL at all.
All i can see is device 0 and if look closely at loaded dlls in debug panel you can see only Intel OpenCL dlls called.
Posted: Thu Sep 26, 2019 12:57 am
Just a note.
For OCL use, I found 430.86 version drivers working best for pascal (10XX) and maxwell (9XX) gen. cards. Have a mix of Quadro with 2 GTXs working in parallel in the system, which I wanted to update in August but had stopped working together with newer drivers, so I rolled back. Officially, either GTX/RTX or Quadro pairings are supported in a system. Machine also worked fine for compiling LuxCore OCL versions with old pair of Intel Xeons X5650 (Lenovo D20 WS). Which I replaced with AMD's TR. Which also compiles fine.
Posted: Thu Sep 26, 2019 5:19 pm
by TAO
Thank you for your suggestion, I'm going to try that and let you know if it works.
Posted: Fri Sep 27, 2019 8:55 am
by TAO
No luck with Nvidia driver 430, I don't think is about driver anymore, all other applications, renderers, and even LuxMark work perfectly fine with the current driver.
Also, other OpenCL devices work too.
Maybe it's a bug inside GetOpenCLDeviceDescs() function or maybe something else, I'm not sure.
Posted: Tue Oct 01, 2019 6:10 am
by happyboy
TAO wrote: ↑Fri Sep 27, 2019 8:55 am
I'm not an OpenCL expert, but for our realtime 3D application, on some customer's machine, we have to use NVidia's control panel (windows) to EXPLICITLY set our program to use "advanced 3D graphics" (I can't remember the exact wording), otherwise our program can only detect the integrated graphics card. Maybe you can play with Nvidia control panel to see whether it does the trick.
Posted: Thu Oct 17, 2019 3:58 pm
Please i have a friend of mine " a max user". he want to download and try the plugin.
___ where to download it ?
___ what can be expect. i mean is everything is on part with the blendluxcore plugin ?
Posted: Tue Nov 05, 2019 11:02 pm
by TAO
Hi everybody.
It's been a while since I started to work on LuxMaxCore and here is the very first build of the new plugin.
it is in the beginning stage and needs many works.
3dsMax 2019 download link :
http://3dfine.com/down/lux/LuxCoreMax-v0.0.2.zip
Extract Zip file and run setup.exe.
Also, you need an OpenCL support device to be able to use the LuxMaxCore plugin.
For Intel CPUs/GPUs you can use below link and download the correct version that matches with your hardware :
https://software.intel.com/en-us/articl ... ph-section
For AMD CPUs/GPUs :
https://www.amd.com/en/support
For Nvidia GPUs :
https://www.geforce.com/drivers
Sample Scene just for test reason, download links, and screenshots :
http://3dfine.com/down/lux/004.zip
http://3dfine.com/down/lux/LightEmmision.zip
http://3dfine.com/down/lux/Depth.zip
http://3dfine.com/down/lux/DanishMood.zip
Here what you can expect in this build.
Basic functionality :
Render time
Render Passes
Render to file (debug)
Render types
Samplers
Film Filters
Camera Depth
Materials :
Matte
Architectural
Light :
Skylight (work as default sunlight)
Spot Light
Omni
and more
Your suggestions and feedback would be appreciated.
Source code will be pushed into the repository as soon as I have enough time to do a few code clean up.
Posted: Wed Nov 06, 2019 9:18 am
TAO, you should "advertise" the new plugin on some 3DsMax forum in order to gather users for testing, further development, etc. I don't know the 3DsMax community but I assume there is something like
https://blenderartists.org
Posted: Wed Nov 06, 2019 9:34 am
by TAO
Dade wrote: ↑Wed Nov 06, 2019 9:18 am
Yes, you right about that, I'll try my best but I'm so busy and it may take some time.
Thank you for your advice.
