Page 59 of 67
Posted: Sun Apr 25, 2021 1:55 pm
by TAO
patro wrote: Wed Apr 21, 2021 5:41 pm I had really no time to test the latest build.
made just 2 renders
one with caustics
May I ask to whom is on max 2022 to try to rebuild the LuxTeapot using the Retopology tools? thanks
Retopology is just a plugin you can install it with 3dsmax 2020, 2021, and 2022. it is available on the Autodesk website and many other places.
I can also give it a shot but in my experience with this type of object, it will not be that good, because it works best when the object normal is perfectly in place and with bodyobjects it's not always the case.
Teapot-BodyObject.zip
(2.05 MiB) Downloaded 162 times
Check this one and see if this is what you want.
Almost half the size of the original file, of course, maps are optimized too.
Posted: Sun Apr 25, 2021 3:15 pm
by patro
TAO wrote: Sun Apr 25, 2021 1:55 pm
made just 2 renders
one with caustics
Thank you for your effort.
This pic is the render of the teapot you posted.
I think that the body object option is still the best option.
Reflection and smoothness of the surface are almost perfect in the body object version, when geometry is set to fine as shown.
Of course it is a bit bigger in size, but it renders fast anyway.
Posted: Wed Apr 28, 2021 3:06 pm
by zbugja
Hi there. I just got back on the LuxTrain after 10 years and wanted to try it out so I installed max 22 but the problem is that I cannot get it to render anything in OPENCL mode. CPU modes work, GPU doesn't ( i have rtx2070). Am I missing something? Thanks
Posted: Wed Apr 28, 2021 9:04 pm
by TAO
zbugja wrote: Wed Apr 28, 2021 3:06 pm Hi there. I just got back on the LuxTrain after 10 years and wanted to try it out so I installed max 22 but the problem is that I cannot get it to render anything in OPENCL mode. CPU modes work, GPU doesn't ( i have rtx2070). Am I missing something? Thanks
Welcome, If you look at the first line of the release note I explained that. The first time you use the GPU render plugin will try to Compile the Kernels and it can take up to 5 minutes base on the PC configuration, it's not a crash nor a bug.
So when you choose GPU as a renderer just for the first time you should be a little bit patient, luxcore will build the kernels and after that, you do not need to wait for anything.
If you have any problem again let me know.
Posted: Thu Apr 29, 2021 7:02 pm
by TAO
Add missing material parameters :
Shadow transparency and color
Bump offset sample
shadow catcher
Posted: Thu Apr 29, 2021 7:44 pm
by TAO
Also, Dispersion for glass.
Posted: Thu Apr 29, 2021 9:03 pm
by patro
Great!! New build will be next week?
Posted: Thu Apr 29, 2021 9:53 pm
by TAO
patro wrote: Thu Apr 29, 2021 9:03 pm Great!! New build will be next week?
Probably earlier next week.
Posted: Thu Apr 29, 2021 10:23 pm
by TAO
Adding LightPaths Tracing Options.
Total Depth options
Diffuse depth
specular depth
glossy depth
light rays
glossiness
clamping
Posted: Thu Apr 29, 2021 10:37 pm
by Ericka
TAO wrote: Thu Apr 29, 2021 10:23 pm Adding LightPaths Tracing Options.
Total Depth options
Diffuse depth
specular depth
glossy depth
light rays
glossiness
clamping
Great. That's exactly what was missing for glass and caustic right? that's why i did not get the good result with caustics!
