Disney BRDF material
Re: Disney shader problem
I changed the materials in the classroom scene to Disney shaders and started rendering the animation (with PGI).
First I was positively surprised to see a substantial speed-up from 190s to 150s render time for 400 samples per frame.
But when I took a peek at the animation after the first 200 frames there was a slight flickering on the wall that was not present in the previous render with glossy and matte materials.
It turns out that the advanced GGX reflectance model throws more noise around the scene.
The light distribution is also very different, two examples without OIDN: ^ Disney
v glossy&matte (only floor, walls & desks; same cache) I'm rerendering now with 500 samples/frame which is the same duration as with the old materials and will report tomorrow how that turns out.
Re: Disney BRDF material
After comparing animations of 500 samples per frame with Disney materials vs 400 samples glossy/matte (same render time)
I have to say there is no free lunch
The Disney version shows slight flickering in the corners where the walls meet the ceiling.
Probably needs 600 to 700 samples to get clean, meaning a three days instead of two days render
It could be caused by GGX model being more noisy, PGI brute force corner blending, OIDN or any combination of those
I just spend two hours to set up a demonstration video showing the effect (0.5GB ProRes 422HQ), then converted it to HEVC for upload and found that the h.265 conversion is somehow smoothing out things and the flicker is nearly gone
Well, yeah.
Theoretically the GGX thingy should be more expensive to render and produce more noise from those fancy reflections at grazing angles, especially with diffuse surfaces that now have a "specular" component (disabling this for walls and ceiling shortens render time by 5s and slightly darkens parts of the room) and that's what I have seen in Cycles and now LuxCore as well.
In the end it's a matter of taste.
Well, yeah.
epilectrolytics, thank you for testing the new shader in-depth.
Could you open bug reports in https://github.com/LuxCoreRender/LuxCore/issues/new with the following:
- short description of the problem
- scene showing the problem (.blend or, even better, result from LuxCore scene export in text format)
- render output images showing the problem
- a description of the steps to make to replicate the problem
When problems are only reported in posts in a 10 page long thread, it is very hard to find them again.
Do you have direct cache enable ? Or single map ?Theoretically the GGX thingy should be more expensive to render and produce more noise from those fancy reflections at grazing angles, especially with diffuse surfaces that now have a "specular" component (disabling this for walls and ceiling shortens render time by 5s and slightly darkens parts of the room) and that's what I have seen in Cycles and now LuxCore as well.
Sorry for being unclear in my reporting but this was not a bug report, instead all is well with the new shader and it works as (at first) expectedB.Y.O.B. wrote: Sat Jun 15, 2019 1:29 pm Could you open bug reports in https://github.com/LuxCoreRender/LuxCore/issues/new
I was just confused about the faster render time per sample and had to learn through experimenting that at the same time it converges slower so in the end there is a certain noise penalty due to the more complex reflection model, just as in Cycles or other apps.
So by all means everyone go ahead and use it because it works
Single map.
Hi there,
I noticed something with Disney material. It seems with CPU rendering, specular gets a color tint. OpenCL gives expected results.
First image is CPU, second one is OpenCL.
I should have fixed this problem.Taka wrote: Tue Jun 18, 2019 4:00 pm I noticed something with Disney material. It seems with CPU rendering, specular gets a color tint. OpenCL gives expected results.
The Disney BRDF has a different roughness scale, how does this work with glossiness.userthreshold parameters in PGI and hybrid path?
Worst case would be when a user mixes f.i. metal + Disney materials and the respective roughness values don't mean the same.
Probably there is no easy solution, somehow it's always unintuitive or backwards compatibility becomes an issue (if Luxcore would adapt Disney roughness scale).
The values is used as it is and compared with the threshold.epilectrolytics wrote: Thu Jun 27, 2019 9:36 am The Disney BRDF has a different roughness scale, how does this work with glossiness.userthreshold parameters in PGI and hybrid path?
If you mean the use of "mix" material: Disney material already includes a metal component so it doesn't make any sense to mix with metal (or glossy2).epilectrolytics wrote: Thu Jun 27, 2019 9:36 am Worst case would be when a user mixes f.i. metal + Disney materials and the respective roughness values don't mean the same.
