Page 10 of 67
Re: MaxLuxCore - 3ds Max Integration for LuxCore
Posted: Wed Nov 06, 2019 5:56 pm
by a1-kh
I can confirm you right now guys a successful Multi GPU rendering of TAO's plugin.. Congratulations TAO , and happy rendering to all LuxCoreRender community people :lol: :lol: :lol: :P :P :P :D :D :D :roll: :roll: :roll:
Thank you so much TAO for the hard work, and i hope i can be of a help
sorry i totally forgot, i have only 3dmax 2019 64bit version, i don't have a 32 bit .
and i will look for the environment variables and try to take a picture of them.
once again , thank you so much TAO
Best regards
Posted: Wed Nov 06, 2019 5:58 pm
by TAO
a1-kh wrote: Wed Nov 06, 2019 5:56 pm I can confirm you right now guys a successful Multi GPU rendering of TAO's plugin.. Congratulations TAO , and happy rendering to all LuxCoreRender community people :lol: :lol: :lol: :P :P :P :D :D :D :roll: :roll: :roll:
Glad to hear that.
Posted: Wed Nov 06, 2019 6:20 pm
by a1-kh
but as you said TAO it is still in testing phase, so i will keep testing the scene files and keep up to date if had any bugs :mrgreen: .
is there a specific test, or testing parameters you would like me to try ?
Best regards
Posted: Wed Nov 06, 2019 9:08 pm
by TAO
Is there any denoiser filter i can use or add to the plugin, i search luxcore wiki but found nothing about it.
i found AMD AI-Denoiser interesting, did anyone ever consider it. and of course there are so many other filter avilable with API.
https://radeon-pro.github.io/RadeonProR ... rning.html
Posted: Wed Nov 06, 2019 9:51 pm
TAO wrote: Wed Nov 06, 2019 9:08 pm Is there any denoiser filter i can use or add to the plugin, i search luxcore wiki but found nothing about it.
We use Intel Oidn, we have an image pipeline plugin for the task. It can be configured like:
# First image pipeline without the denoiser
film.imagepipelines.0.0.type = TONEMAP_LINEAR
film.imagepipelines.0.1.type = GAMMA_CORRECTION
film.imagepipelines.0.1.value = 2.2
# Second image pipeline with the denoiser
film.imagepipelines.1.0.type = INTEL_OIDN
film.imagepipelines.1.1.type = TONEMAP_LINEAR
film.imagepipelines.1.2.type = GAMMA_CORRECTION
film.imagepipelines.1.2.value = 2.2
It works better if you enable ALBEDO and AVG_SHADING_NORMAL AOVs:
## Output of the first image pipeline
film.outputs.0.type = RGB_IMAGEPIPELINE
film.outputs.0.index = 0
## Output of the second image pipeline
film.outputs.1.type = RGB_IMAGEPIPELINE
film.outputs.1.index = 1
## AOVs used by Intel ODIN
film.outputs.2.type = ALBEDO
film.outputs.3.type = AVG_SHADING_NORMAL
film.outputs.3.filename = cornell_AVG_SHADING_NORMAL.exr
Posted: Thu Nov 07, 2019 9:17 am
by TAO
Thanks Dade.
i tried it and the result is not as good as i expected maybe i miss something.
Without INTEL_OIDN denoiser.
With INTEL_OIDN denoiser.
Posted: Thu Nov 07, 2019 9:33 am
TAO wrote: Thu Nov 07, 2019 9:17 am i tried it and the result is not as good as i expected maybe i miss something.
Can you post the scene in text format (.cfg, .scn, etc.) ? You can use the RenderConfig::Export() method or the FILESAVER render engine.
Posted: Thu Nov 07, 2019 10:28 am
by TAO
This is my last test configuration.
the problem will show up on Light Emmision Materials and specially with red or perpul color.
render.cfg
(1.19 KiB) Downloaded 774 times
Posted: Thu Nov 07, 2019 10:37 am
TAO wrote: Thu Nov 07, 2019 10:28 am This is my last test configuration.
render.cfg
TAO, Intel Oidn must be the first plugin to be execute, not the last:
film.imagepipeline.0.type = "INTEL_OIDN"
film.imagepipeline.1.type = "TONEMAP_AUTOLINEAR"
film.imagepipeline.2.type = "TONEMAP_LUXLINEAR"
film.imagepipeline.2.sensitivity = "100.0"
film.imagepipeline.2.exposure = "2.4"
film.imagepipeline.2.fstop = "2.8"
film.imagepipeline.3.type = "GAMMA_CORRECTION"
film.imagepipeline.3.value = "2.2"
film.imagepipeline.3.table.size = "4096"
Running the plugin also take time so you probably need at least 2 pipelines: one without the plugin and one with the plugin, like in my example. The first one can be used to update the screen, the second will be run only on explicit request of the user or at the end of the rendering.
Note also, you are referencing the "1" pipeline but you have only defined the "0" so the following lines will be ignored:
film.outputs.1.type = "RGBA_IMAGEPIPELINE"
film.outputs.1.index = "1"
film.outputs.1.filename = "denoised.png"
Posted: Thu Nov 07, 2019 1:21 pm
by TAO
Thank you.
It's work now, but it's too blurry.
Can you show me any reference to how you do the image pipeline after rendering?
