Page 84 of 109
Re: PhotonGI cache
Posted: Fri Mar 15, 2019 1:09 pm
by the way... Is the difference between cache from cpu and opencl solved?
I'm asking because in my scene I solved it by deleting and relinking some objects (floorboards specificaly) But I don't know why it would matter at all..
The problematic part in this scene regarding overall performance is that there seems to be mostly a lot of direct light sampling (a lot of windows) which creates a lot of shadows and that noise is incredibly slow to resolve even though photongi makes rays/sample go down to 3 from +/-5.9...
EDIT: it seems that sigma other than 0 also seem to do something to cache, I had my matte material for wall using sigma of 6.3 for some reason and it definitely resulted in worse performance and worse looking cache too!
Re: PhotonGI cache
Posted: Fri Mar 15, 2019 2:16 pm
by Fox
Does PhotonGi support only clear volume type, no hetero?
Re: PhotonGI cache
Posted: Fri Mar 15, 2019 4:40 pm
Fox wrote: Fri Mar 15, 2019 2:16 pm
Nope
Re: PhotonGI cache
Posted: Fri Mar 15, 2019 5:00 pm
by Fox
I probably need to go below 0.0001 radius and indirect.usagethresholdscale = 12000
Or maybe it's about the sampling efficiency, the small area takes about 90% render time, when i use linear random sampler with path-cpu, i see it's stuck there.
Re: PhotonGI cache
Posted: Sun Mar 17, 2019 12:19 am
by Fox
95% sure the hetero volume covers slow because the dense mesh has normals pointing in different directions and the triangles are very small.
Upped the visibility.maxsamplecount so high it took 1 hour, no help there.
Then i thought maybe photon path depth has to be higher than hetero volume max steps. Then i upped the path depth to 10500 and took photon number 200 times smaller. Did not work.
Very small radius like 0.00001 displayed error MLT can't find usable light sources.
The numbers under the clear glass come out, slow, but they come. The mesh is not ideal.
But the clear glass type on camera lens with dispersion enabled seems to work so well.
Re: PhotonGI cache
Posted: Tue Mar 19, 2019 9:09 am
So I'm now 100% sure that the weird and noisy cache is happening due to bump mapping!
cpucache:
opencl/hybridcache:
opencl/hybrid cache without bump mapping in materials!:
Re: PhotonGI cache
Posted: Tue Mar 19, 2019 9:18 am
lacilaci wrote: Tue Mar 19, 2019 9:09 am
I should have fixed this yesterday:
https://github.com/LuxCoreRender/LuxCor ... c3ab7b9bb0 https://github.com/LuxCoreRender/LuxCor ... f8c371039e
Does it still happen with the latest version ?
Re: PhotonGI cache
Posted: Tue Mar 19, 2019 11:16 am
Oh, I didn't notice that in the azure builds, will download latest and test
EDIT: Ok, it seems that latest build doesn't have this problem
Re: PhotonGI cache
Posted: Tue Mar 19, 2019 4:46 pm
I added the support for volumes to PhotonGI. Now cache entries can be created and used on volumes too:
It can increase the raw samples/sec by a 50%-100% and reduce the amount of noise too:
In particular, it greatly accelerate the rendering of multi-scattering volumes and it is indicated for SSS rendering.
NOTE: for obvious reasons, covering with cache entries a 3D volume is more complex than a 2D surface so there may be cases, like a large air volume for a large open scene, where it is not practical. In that case, just check the disable PGI flag for that particular volume.
Re: PhotonGI cache
Posted: Tue Mar 19, 2019 5:02 pm
Nice add
this should be written in tooltips :
"NOTE: for obvious reasons, covering with cache entries a 3D volume is more complex than a 2D surface so there may be cases, like a large air volume for a large open scene, where it is not practical. In that case, just check the disable PGI flag for that particular volume."
