Re: PhotonGI cache
Posted: Wed Mar 13, 2019 8:21 pm
Ah yes, now I remember when this was discussed back in this thread!
And it works great, thanks Dade!
path.photongi.indirect.haltthreshold = 1.0Code: Select all
path.photongi.photon.maxcountIt is a number between 0.0 and 1.0 where:Fox wrote: Wed Mar 13, 2019 8:33 pm How do i use this:Code: Select all
Just use a very high max. photon countFox wrote: Wed Mar 13, 2019 10:21 pm Can it be done so it will go over the bucketuntil the % is reached?
Okay, maybe together with very high value of that path.photongi.indirect.usagethresholdscale
[LuxCore][10600.391] PhotonGI Cache photon traced: 4294729728/4294967295 [100.0%, 411.9M photons/sec, Map sizes (42.5%, 0.1%)]
[LuxCore][10602.500] PhotonGI Cache photon traced: 655360/4294967295 [0.0%, 0.1M photons/sec, Map sizes (42.5%, 0.1%)]Can such kind of things be automated ?Dade wrote: Wed Mar 13, 2019 4:24 pmThe look up radius must be smaller of half of the door depth. So specify the radius by hand to a value like 1cm. To balance the very small radius you have also to scale back the brute force parameter (so from 6 to something like 6 * 15 = 90). And you get the correct result:epilectrolytics wrote: Wed Mar 13, 2019 2:25 pm Did I do something wrong modeling the door or is it a PGI issue?
Not really, without an absurd amount of pre-processing to catch the "radius greater than some (important) geometry feature" problem.
You can not use 2^32 as input otherwise 32bit integers will overflow at first computation, use 2^31 if you really need to use an absurdly high value.Fox wrote: Wed Mar 13, 2019 11:40 pm EDIT
Seems like when using maximum value, it continues shooting photons.Code: Select all
[LuxCore][10600.391] PhotonGI Cache photon traced: 4294729728/4294967295 [100.0%, 411.9M photons/sec, Map sizes (42.5%, 0.1%)] [LuxCore][10602.500] PhotonGI Cache photon traced: 655360/4294967295 [0.0%, 0.1M photons/sec, Map sizes (42.5%, 0.1%)]
Looks like it must have gone 3'rd or 4'th time back to 0 with 2^32 photons. 1'st time map size was 0.1%, now it's 0.8% and memory use is 123GBDade wrote: Thu Mar 14, 2019 10:09 am You can not use 2^32 as input otherwise 32bit integers will overflow at first computation, use 2^31 if you really need to use an absurdly high value.
