Page 76 of 92
Re: BlendLuxCore Development
Posted: Mon Apr 20, 2020 1:04 pm
Can the opencl compiling be remove in the current alpha of 2.4 ? it is annoying to that it tell you it will happen once and come again and again. at the ends you don't know what to believe
i mean that it really happen once ?
Posted: Mon Apr 20, 2020 1:09 pm
I will get there.
Posted: Thu Apr 23, 2020 7:51 am
by marcatore
With the merging of the CUDA branch I imagine that we've to wait an update for BlendLuxCore to use it. Right?
At the moment, the last BlendLuxCore build has just removed the OpenCL support.
Posted: Thu Apr 23, 2020 10:37 am
marcatore wrote: Thu Apr 23, 2020 7:51 am
Also what are the final name to switch between opencl or CUDA ?
Posted: Thu Apr 23, 2020 10:58 am
Not really, not only because CUDA is not enabled in current builds (see below) but because CUDA devices are listed together with OpenCL devices and they can be mixed and used as you like.
BlendLuxCore will have only to be careful to not use a NVIDIA GPU 2 times: one as OpenCL device and one as CUDA.
This was a mistake, I should have re-enabled the OpenCL support by default (while CUDA is still disabled because we don't know yet how to compile CUDA binaries on Azure).
Posted: Thu Apr 23, 2020 11:01 am
Sharlybg wrote: Thu Apr 23, 2020 10:37 am
There isn't really the need of a switch (see above how CUDA and OpenCL devices are listed). It is just strange to have something called PATH
OCL able to use CUDA devices too so I would like to change the name for consistency.
In BlendLuxCore, we could simply have the label "OpenCL" replaced with "OpenCL/CUDA".
Posted: Thu Apr 23, 2020 11:04 am
So we have to wait that all settle down between Luxcore and blendluxcore befor testing correctly
Posted: Thu Apr 23, 2020 11:23 am
Sharlybg wrote: Thu Apr 23, 2020 11:04 am
No, you only need a CUDA enabled pyluxcore.pyd and to select the devices to use for the rendering by hand in BlendLuxCore (or it will use 2 times the same GPU).
Posted: Thu Apr 23, 2020 12:24 pm
So finally is just install lastest build from luxcore and blendluxcore like before do the trick ?
Posted: Thu Apr 23, 2020 12:46 pm
Sharlybg wrote: Thu Apr 23, 2020 12:24 pm
Yes (when CUDA compilation is enabled on Azure).
