Page 75 of 109
Re: PhotonGI cache
Posted: Mon Mar 04, 2019 1:54 pm
Not at the moment, like I wrote before, the average value of the texture is estimated and used for a comparison with the glossiness threshold. But using not constant roughness sounds quite uncommon to me :?:
it is far more common than you think. if you have a texture modified inside a band node (what i do every day) you will probably have to :
tweak ----> debug view render ----> tweak ----> debug view render ----> tweak ----> debug view render ----> tweak ----> debug view render
until i found a good compromise between my large surface shader and cache set.
Re: PhotonGI cache
Posted: Mon Mar 04, 2019 1:58 pm
by marcatore
B.Y.O.B. wrote: Mon Mar 04, 2019 11:28 am I have changed the defaults in BlendLuxCore and exposed the new debug mode.
I've downloaded the lastest BlenderAddon and LuxCore build (Downloaded 20 minutes ago) but when I tried the new debug mode I've this error
"Unknown PhotonGI cache debug type: showindirectpathmix"
It seems that or the build it's not the lastest or there is some mismatching.
Just me? Anyone tried this?
Re: PhotonGI cache
Posted: Mon Mar 04, 2019 2:05 pm
marcatore wrote: Mon Mar 04, 2019 1:58 pm It seems that or the build it's not the lastest or there is some mismatching.
Maybe azure was not yet done?
Your binaries are outdated, the addon is fine.
Re: PhotonGI cache
Posted: Mon Mar 04, 2019 2:06 pm
Dade wrote: Mon Mar 04, 2019 1:46 pm
Sharlybg wrote: Mon Mar 04, 2019 12:52 pm Also something i want to understand.
Is there anyway to know if given glossy shader will be included in cache or not if we aren't using number to set roughness (reflection texture ) ?
Textured/mapped roughness is pretty standard thing to do
Re: PhotonGI cache
Posted: Mon Mar 04, 2019 2:07 pm
by CodeHD
Sharlybg wrote: Mon Mar 04, 2019 1:54 pm
Sounds quite common/realistic to me as well. For example when you try to achieve a "used look", e.g. a leather seat used to be shiny but has been worn off in some areas, or a bronze statue in a public place, which are partly coroded and partly polished where people touch it. Like in this example, the polished areas look very glossy, so this might even fall around the threshold value.:
Re: PhotonGI cache
Posted: Mon Mar 04, 2019 2:35 pm
Dade wrote: Mon Mar 04, 2019 1:46 pmBut using not constant roughness sounds quite uncommon to me :?:
I have run this script on our three example scenes:
Sharlybg's Food scene:
34 roughness sockets, 9 are textured (26%)
Sharlybg's Benchmark scene:
21 roughness sockets, 5 are textured (23%)
Sharlybg's DLSC scene:
12 roughness sockets, 3 are textured (25%)
Re: PhotonGI cache
Posted: Mon Mar 04, 2019 2:50 pm
Note also that theses scene are relatively simple one. And also 25% is for the number of textured vs constant roughness not the percentage of the surface covered by of the shader in a complexe production scene.
Re: PhotonGI cache
Posted: Mon Mar 04, 2019 4:35 pm
B.Y.O.B. wrote: Mon Mar 04, 2019 2:35 pm
I can add to the API a new method that, given the complete properties definition of a texture, returns the average value. Is it what do you want ?
Re: PhotonGI cache
Posted: Mon Mar 04, 2019 5:12 pm
Dade wrote: Mon Mar 04, 2019 4:35 pm I can add to the API a new method that, given the complete properties definition of a texture, returns the average value. Is it what do you want ?
I just wanted to check how often roughness is textured.
It sounds to me like Sharlybg wants a text in the node UI that says something like "this material will be cached because the roughness is higher than the threshold" (or the opposite)?
However this is a bit hard to do in a convenient way. It would require to evaluate the whole nodetree that goes into the roughness socket, just for the Blender UI, and would probably slow things down if run constantly. Or you have to run it with a button, which kinda defeats the purpose as well.
Dade, I think you mentioned a "force cache off/on/auto" solution once, maybe this would also help?
Re: PhotonGI cache
Posted: Mon Mar 04, 2019 5:36 pm
Simple way : just have roughness number still displayed evenif i have node texture pluged in just to show the average roughness value the cache will be compared to.
