Page 71 of 92
Re: BlendLuxCore Development
Posted: Sat Mar 14, 2020 5:58 pm
The whole HDRI transformation thing is a bit screwed up, even if you use the LuxCore HDRI settings on a sun light.
We'll have to fix that eventually.
Posted: Thu Mar 19, 2020 12:06 pm
I have modified the material shading mode in the viewport (aka LookDev).
It is now no longer using Eevee (which requires Eevee shaders to preview materials).
Instead, I am using an RTPATHCPU engine with optimized settings and the Albedo AOV as the visible output in the viewport.
Here's a demo video:
https://youtu.be/mzxQaxemWHI
It's not perfect in all areas, but should be much more useful for adjusting diffuse textures than what we had before.
If you have ideas or feedback about it, you can post them here:
https://github.com/LuxCoreRender/BlendL ... issues/322
Posted: Thu Mar 19, 2020 12:17 pm
Wonderfull Simon.
Posted: Thu Mar 19, 2020 9:08 pm
by juangea
This is awesome Simon!
For the future could be great to have a super fast render mode (like a direct light mode or something like that) for this, and an option to pick between different AOV's or the fast light mode, it would be helpful also to seetup lighting in a fast way, without a full path traced result
Posted: Fri Mar 20, 2020 6:06 am
by neo2068
Great feature, B.Y.O.B.
Posted: Fri Mar 20, 2020 10:10 am
by marcatore
Yes... it's great and , following the ideas on the github about this, I think that it will be super useful
Posted: Fri Mar 20, 2020 12:53 pm
by sarmath
Great! This is a time saver
Posted: Sat Mar 21, 2020 9:46 am
by Racleborg
Great. Thank you.
Posted: Sat Mar 21, 2020 1:17 pm
https://youtu.be/2kFrw5FMIp0
Anything else you miss from node wrangler?
Posted: Sat Mar 21, 2020 3:42 pm
Ctrl+t to create image node+attached mapping node
Great work btw.
