Page 61 of 109
Re: PhotonGI cache
Posted: Tue Feb 26, 2019 10:01 pm
Dade wrote: Tue Feb 26, 2019 9:44 pm
lacilaci wrote: Tue Feb 26, 2019 8:51 pm Also cache size and photon count should be calculated to fill some criteria, maybe coverage in screen space or something, instead of guessing how much photons to cast and how big cache should be
Screen coverage would be a good criteria, the problem is in having a constant radius: one pixel covers 15cm at 1m of distance and 150m at 1km (random numbers, just to give you an idea of where the problem is).
but do you need good coverage at that distance? If a tree crown far away is represented by 50 pixels, I dont care if it contains 50 photons...
I think vray's lightcache is somehow resolution dependent too (not sure how it works, but something is controlled by resolution so screen space is controlling something)
Re: PhotonGI cache
Posted: Tue Feb 26, 2019 11:14 pm
lacilaci wrote: Tue Feb 26, 2019 10:01 pm but do you need good coverage at that distance? If a tree crown far away is represented by 50 pixels, I dont care if it contains 50 photons...
That is exactly the problem, like I wrote, the radius is constant at the moment: pixels can cover 15cm like 150m in the same scene, do I pick 15cm or 150m as constant radius ? Do I pick the minimum covered area ? The average ? It is a bit arbitrary.
Re: PhotonGI cache
Posted: Wed Feb 27, 2019 12:07 am
Finally find time to optimized This kitchen here : https://blenderartists.org/t/lux-corona ... 1143996/57 for luxcore 2.2 and guest what :D
Note that the scene original rendertime was arround 1h45mn on Luxcore 30mn under corona and 45mn for Cycles (Due to lot of inappropriate settings and workflow).
Pure Path 20 mn 1080ti + i7 8700k
PGI 5mn 1080ti + i7 8700k
PGI settings
Re: PhotonGI cache
Posted: Wed Feb 27, 2019 11:06 am
Sharlybg wrote: Wed Feb 27, 2019 12:07 amPGI 5mn
Crazy, considering that this is how the indirect light cache looks like:
Re: PhotonGI cache
Posted: Wed Feb 27, 2019 11:14 am
try glossiness at 0.0 ... just for fun
Re: PhotonGI cache
Posted: Wed Feb 27, 2019 11:58 am
(all images below rendered for 5 minutes plus export/init time)
When I render the scene for 5 minutes with Sharlybg's settings, I get no noticeable difference between PGI on and off. Even the samples/sec and rays/sample are nearly equal.
This seems to be caused by the fact that only very few surfaces fall above the glossiness threshold and are cached, as you can see in the post before.
The attachment PGI_off_430samples.png is no longer available
The attachment PGI_on_440samples.png is no longer available
I set the glossiness threshold to 0.03 to include more materials in the cache.
This makes the scene benefit a lot more from the cache (as you can see from the higher amount of samples in equal time), but note how the ceiling lights now directly show the cache in the reflections, making them wrong.
The attachment PGI_on_750samples_glossThresh0.03_debugview.png is no longer available
The attachment PGI_on_750samples_glossThresh0.03.png is no longer available
This can be fixed by setting the usage threshold scale from 1 back to the default of 4, which causes LuxCore to fallback to pathtracing for small details like these ceiling lights (another option would be to disable caching for the ceiling lights in the material output node settings).
However, note how you can see a rim around the black furniture on the right where it meets the wall - this is the border between brute-force pathtracing (where it meets the wall) and cache (everywhere else). This is the reason why the glossiness threshold is 0.2 by default, as this surface should not be included in the cache. In this scene, we could disable cache usage in the material output node settings.
debug view of lowered glossiness threshold
edit: the last render was the denoised verison by mistake, I re-uploaded the raw version.
Re: PhotonGI cache
Posted: Wed Feb 27, 2019 12:04 pm
So it is AAAAMMMMAAAAAZING :shock:
Re: PhotonGI cache
Posted: Wed Feb 27, 2019 12:07 pm
Your last render hardware ? Also 5mn ?
Re: PhotonGI cache
Posted: Wed Feb 27, 2019 12:18 pm
Sharlybg wrote: Wed Feb 27, 2019 12:07 pm Your last render hardware ? Also 5mn ?
Yes, all renders are 5min. Plus export (10s) and init (15s) which includes cache building. Since these are fixed costs regardless of the render time, I don't consider them too important here.
I used an RTX 2080 (only OpenCL, no CPU involved).
Re: PhotonGI cache
Yes of course those extreme settings are wrong.
But this is near production quality at preview rendertimes. This is pure gold for archviz work cause you know exactly what are you working up to. Now imagine if we could have that times aand also problem free :D
