Page 7 of 109
Re: PhotonGI cache
Posted: Sun Jan 20, 2019 10:39 am
Added the support for a new material property to enable/disable PhotonGI on a specific surface. Updated the first post with the property description.
Mostly useful for glossy nearly specular surfaces as explained here:
viewtopic.php?f=5&t=840&start=30#p8885
Re: PhotonGI cache
Posted: Sun Jan 20, 2019 12:14 pm
by epilectrolytics
The development is so fast I cannot keep up testing
ATM tweaking photon counts and the other parameters is quite tricky.
Will it be possible to automate them like adaptive/progressive photon mapping that stops when density is sufficient?
Also lookup.maxcount/radius/normalangle are difficult to estimate.
Do we need to become experts for those or will they work automatically "under the hood" later?
Re: PhotonGI cache
Posted: Mon Jan 21, 2019 9:22 am
Added a new property ("path.photongi.debug.type") to force the direct visualization of one of the cache. It helps to establish if a cache is "good enough".
For instance, not enough photons:
Good enough:
Updated the first post with this information.
Re: PhotonGI cache
Posted: Mon Jan 21, 2019 9:30 am
Is it possible to show this while the cache is building, then switch to normal film mode when the render starts?
Re: PhotonGI cache
Posted: Mon Jan 21, 2019 9:51 am
B.Y.O.B. wrote: Mon Jan 21, 2019 9:30 am
You mean, like showing it as visual progress of building the photon map before rendering starts? (like when vray shows previz when building lightcache)
Re: PhotonGI cache
Posted: Mon Jan 21, 2019 9:58 am
Yes.
Re: PhotonGI cache
Posted: Mon Jan 21, 2019 10:08 am
It would have an (high) cost because I would have to trace (useless for photon mapping) eye rays to give the feedback.
I can move the cache creation from the pre-processing stage to the rendering with the benefits that the rendering can be stopped while pre-processing can not. If I do this, it should be possible to offer some feedback but it will look like a LIGHTCPU rendering:
Each traced photon will light up a single pixel, not a multiple "splotches" like in:
After, the caches creation is done, the film is reset and the normal rendering starts.
Re: PhotonGI cache
Posted: Mon Jan 21, 2019 10:22 am
I think the need for this depends on how much trial and error is involved to find the right settings for the PhotonGI cache.
If you need a lot of trial and error, starting 10 renders or so until you found good setttings for photon count, radius etc., then it would be very good to have this pre-visualization.
On the other hand, if we manage to make this setting-finding process automatic or super fool proof, I think it would be ok to skip the pre-viz step.
Re: PhotonGI cache
Posted: Mon Jan 21, 2019 10:27 am
B.Y.O.B. wrote: Mon Jan 21, 2019 10:22 am
It depends a bit of where we will land at the end. I have some idea, after we have the photon tracing with Metropolis sampler and I have tried my idea for something like a BiDir photon tracing (i.e. firing photons form light sources and "visibility" particles from the eye) we should know more.
Re: PhotonGI cache
Posted: Mon Jan 21, 2019 10:55 am
Agreed.
