Page 7 of 31
Posted: Tue May 28, 2019 10:59 am
This looks so good!
Posted: Tue May 28, 2019 11:19 am
striking result : something like LUXCORE PATH TRACING TENSOR CORE.
LTX OFF =====> :cry:
LTX ON =====> :twisted:
LOL
More seriously:
It doesn't, it is an additional option (the pre-processing require far more time and memory than the old visibility map, so the old could be still useful).
how many time for this one ? how much additional memory ?
I'm working on the integration in BlendLuxCore.
It seems that when enabling both vismap + vismapcache, only the latter is computed, is that correct?
Should I expose this as three exclusive radio buttons in the UI?
- nothing
- vismap
- vismapcache
By the way, here's a comparison of the three (direct light only, 10 samples each):
Posted: Tue May 28, 2019 12:28 pm
by marcatore
well...for that specific case it's fantastic...
I hope we'll benefit both on other complex situation.
Anyway, everything will help to have a better and cleaner image is more than welcome.
Posted: Tue May 28, 2019 12:32 pm
I'm still seeing those artifacts that look almost like jpeg compression artifacts.. do they go eventually away?
Also is this stable across frames? Would it cause flickering?... so many questions, but it definitely looks to be on par with how well portals work in other renderers
Posted: Tue May 28, 2019 1:26 pm
B.Y.O.B. wrote: Tue May 28, 2019 11:19 am I'm working on the integration in BlendLuxCore.
Yes, vismapcache has precedence over vismap.
B.Y.O.B. wrote: Tue May 28, 2019 11:19 am Should I expose this as three exclusive radio buttons in the UI?
- nothing
- vismap
- vismapcache
Yes, it is like an escalation:
- nothing, only importance sampling, no additional memory, no pre-processing time;
- vismap, only additional memory for a single map, only pre-processing time for a single map;
- vismapcache, additional memory for multiple maps, pre-processing time for multiple maps;
Posted: Tue May 28, 2019 1:28 pm
lacilaci wrote: Tue May 28, 2019 12:32 pm I'm still seeing those artifacts that look almost like jpeg compression artifacts.. do they go eventually away?
Yes, they should, it is just a different amount of noise due to different chance entry/visual map.
Posted: Tue May 28, 2019 2:58 pm
It looks like the cache doesn't work yet with constantinfinite lights (without HDRI)?
(30 sample renders)
Posted: Tue May 28, 2019 3:10 pm
Oh no, I would hope to get even better result with constant light than hdri (which I rarely use anyway)
Posted: Tue May 28, 2019 3:12 pm
Here's the scene.
By the way, I have pushed first support for it in the Blender addon.
