Page 54 of 92
Re: BlendLuxCore Development
Posted: Sat Jun 08, 2019 6:42 pm
HugTower has implemented a new math texture: rounding.
You can specify the increment to round to.
For example, if the increment is 1, you get no decimal places after rounding: 34.567 -> 35
If the increment is 0.1, you get one decimal place: 34.567 -> 34.6
The increment can be textured.
I have added the support in BlendLuxCore on the 2.79_maintenance branch:
https://github.com/LuxCoreRender/BlendL ... aintenance
Posted: Sat Jun 08, 2019 8:20 pm
The 2.8 port is coming along, I'm laying the foundations step by step.
What's working so far:
- the addon registers without errors (I had to edit 150 files to reach this point, a lot of search/replace of course)
- I have ported the viewport draw code to modern OpenGL
- I can start a small, hard-coded testscene that is rendered in the viewport, and I can move the camera around
- I have ported our C++-accelerated mesh conversion code, so I can load meshes from Blender into Lux (at the moment only one object can be used)
What's not working yet:
- Everything else
- Final render, viewport render, material previews are not usable yet
- The whole UI is disabled, meaning that the property window is very empty
- The viewport camera is slightly off for some reason
I'm mostly done with the groundwork though.
Posted: Sat Jun 08, 2019 8:42 pm
Beautyful progress
Posted: Sat Jun 08, 2019 10:21 pm
Wow this is a sooo good news. Nice progress.
Posted: Sun Jun 09, 2019 9:10 am
by provisory
Posted: Mon Jun 10, 2019 6:09 pm
I have renamed the branch "2.79_maintenance" to "2_79_maintenance" because Blender doesn't list the addon if the name contains a dot.
This is the branch where 2.79 fixes will be commited. If you want to use the latest daily builds, download from there.
Posted: Tue Jun 11, 2019 11:38 am
by Piita
What?! Does Blender 2.8 have such a big internal change compared to 2.79 that you have to redo the entire blendluxcore?
Posted: Tue Jun 11, 2019 11:56 am
Oh I see, so there's no master anymore, until 2.8 becomes master?
Posted: Tue Jun 11, 2019 12:17 pm
Piita wrote: Tue Jun 11, 2019 11:38 am
Pretty much, yeah.
That's why I hesitated so long to start this massive project.
lacilaci wrote: Tue Jun 11, 2019 11:56 am
Yes, master will not be used, instead there's one branch for 2.79 and one for 2.8, and eventually the latter will be merged into master.
Posted: Wed Jun 12, 2019 5:53 pm
HugTower has implemented a new math texture: modulo.
It exposes the "fmod" operation:
https://en.cppreference.com/w/cpp/numeric/math/fmod
Meaning that it returns the remainder of the floating point division of value 1 divided by value 2.
