Page 53 of 67
Posted: Fri Mar 26, 2021 1:22 pm
by TAO
I'll take a look at it, my priority right now is to fix the important issues and add support for Multimaterial/SubMaterial, i think the mention feature will be supported during this process.
Posted: Fri Mar 26, 2021 1:33 pm
by patro
test mirror.zip
(325.26 KiB) Downloaded 673 times
Posted: Fri Mar 26, 2021 2:28 pm
by TAO
patro wrote: Fri Mar 26, 2021 1:33 pm test mirror.zip
I see what you mean, that's not an issue with luxCore or MaxToLux. This is a known issue with one of the oldest mirroring tools in 3dsmax, they need to update the code.
https://knowledge.autodesk.com/support/ ... s-Max.html
The only fix is to add an Xform and then a Normal modifier on top of that.
Posted: Fri Mar 26, 2021 2:42 pm
by patro
TAO wrote: Fri Mar 26, 2021 2:28 pm
Oh well good to know. But did you notice that it doesn't hapoen with all materials? i reported a list of them on github
Mirroring probably makes all normals point in the other direction.
Some LuxCore materials act differently depending if it's a backface or frontface, e.g. glossy is only specular on the frontface, but behaves like matte on the backface (https://github.com/LuxCoreRender/LuxCore/issues/301).
You should probably check how other renderers in 3ds max handle this and follow their behaviour. Maybe they detect mirrored objects and flip their normals.
Posted: Fri Mar 26, 2021 2:53 pm
by TAO
B.Y.O.B. wrote: Fri Mar 26, 2021 2:42 pm Mirroring probably makes all normals point in the other direction.
Fliping the normal is exactly the case. That's the same for others rendered like Arnold and even viewport in case of visible reflection. they already add it in the knowing issue in Autodesk knowledge.
The issue will affect only the reflection, as it said on the Autodesk page.
Posted: Fri Mar 26, 2021 3:38 pm
by TAO
patro wrote: Fri Mar 26, 2021 2:42 pm
It will affect only the glassy part of the material, any material with a glassy surface will be affected. Even the viewport glassy/specular as I mention and it is already explained on Autodesk WebSite.
Posted: Fri Mar 26, 2021 3:42 pm
by patro
Ah that's why the behaviour is not to notice with velvet for example. it was driving me nuts.. :D
Posted: Fri Mar 26, 2021 5:31 pm
by TAO
A reported issue with the used bitmap is rendered mirrored if the geometry has no UVW Map modifier applied has been fixed.
Posted: Fri Mar 26, 2021 9:18 pm
by Ericka
I know it is very early to ask and 3ds max 2022 just released, but it would be perfect if we have MaxToLux for 3dsmax 2022.
