Page 6 of 92
Re: BlendLuxCore Development
Posted: Thu Dec 28, 2017 8:47 pm
The new addon now has enough features to replicate my
wallpaper scene.
Here's a quick render (7min Bidir on my laptop):
Posted: Thu Dec 28, 2017 10:13 pm
by Piita
Looking good
Posted: Fri Dec 29, 2017 4:44 pm
B.Y.O.B. wrote: Thu Dec 28, 2017 8:47 pm
wallpaper scene.
Hummm very interesting. your final render on old forum turn around 3hr. i wonder how the new luxcore/blendluxcore combo outperform the old one on same hardware ?
Posted: Fri Dec 29, 2017 4:48 pm
The rendering speed will be about the same, as far as I know there were only small speed improvements in LuxCore code since I rendered the old scene.
Posted: Fri Dec 29, 2017 5:13 pm
B.Y.O.B. wrote: Fri Dec 29, 2017 4:48 pm
There has been some major change/improvement in the OpenCL code but you are using BiDir so it is CPU-only. The only difference is likely to be the Embree version.
Posted: Mon Jan 01, 2018 4:43 pm
by Piita
I have been trying to get a grip on the code but it has been difficult. I managed to get velvet working but I have no idea what I did
But it will come to me, it just requires a lot of practice.
I found it very surprising that I did not have to do anything about saving/loading the blend files. I tried saving it, thinking it will crash when I load the file next time but no, the node was there. Weird but good.
I still want to poke around more before asking any questions though.
- velvet test.jpg (9.31 KiB) Viewed 15094 times
Posted: Tue Jan 02, 2018 8:39 pm
Piita wrote: Mon Jan 01, 2018 4:43 pm
Yes, this is not a beginner project. As a newcomer you will stumble about advanced Python and programming concepts here and there.
I appreciate that you try to learn everything by yourself, but please don't hesitate to ask questions when it gets frustrating. We can also talk about IRC/Skype/Teamviewer etc. if you want.
Before beginning serious work on BlendLuxCore you should do a few lectures of some Python beginner course and maybe write a few small Blender scripts or addons.
That's a nice start. If you push the code to your forked repository I can take a look at it and maybe add a comment here or there.
That's handled by Blender thankfully. We have to register our properties from the bpy.props module (e.g. bpy.props.IntProperty() for a number) and the saving/loading is then handled by Blender in the background.
btw I moved some posts to a dedicated topic on compiling on windows: viewtopic.php?f=5&t=20&p=325
Posted: Wed Jan 03, 2018 1:56 pm
Dispersion should now work properly, even with textured IOR, by using an add texture in the background to do the RGB spread.
Posted: Thu Jan 04, 2018 8:20 pm
I added a pointer node which allows to include any material or texture node tree as a node.
This is useful to avoid node tree duplication: E.g. if you have a complex texture setup, you don't have to copy it if you want to use it in several different material node trees. It's a bit like instancing.
I also added Texture node trees.
Demo Video:
https://www.youtube.com/watch?v=aFvDuCJ ... yucvtzBkN7
Posted: Fri Jan 05, 2018 5:35 pm
I improved the error log. Most missing image maps, missing IES files etc. are now reported as warnings.
Critical exceptions that cause the render to abort show up under "errors".
